Ignition/Starter Sticking
pappy
photosynthesizing
Moderator
Too far north. Too far east.
I'm having a problem on cold mornings. When I start the truck the starter stays engaged even though I've let off the key from the start position. I can even turn the key to engage the starter, turn the key to the off position, remove the key, and the starter stays engaged.
I'm guessing ignition switch, but through I would ask this group before I visit CDan.
Starter is sticking. I had the same problem on an old Corolla. The contacts likely won't fix it though. It's actually the part that makes the plunger go forward. You're prob better to replace the whole thing with a reman. I can get you a price if you want.
Thanks. As I recall this is an OEM reman starter that is probably less than 2 years old.
Your price is $72.72 plus $30 core charge btw. If the starter that is in there now is actually a Toyota starter I can give you the $30 back if you return it. They won't take back a non-Toyota one tho.
