Ignition problems and questions
Metairie Louisiana
Hello I own a 1970 FJ40 with the F engine it has a Mallory duel point distributor. I put off changing the points because I had forgotten how. I could not find a I mechanic that wanted the fool with the job so I Google how how to do it and I jumped in with the attempt. Well it did not go so well I now do not have any spark to the plugs and none coming out of the coil. Any ideas on what I could have done wrong would be greatly appreciate .
thanks
PS: I set the points to eighteen thousands..
Dual point distributors are normally found on high performance engines. You set one set of points to a smaller gap so that it will start to recharge the coil sooner. Wasted on a tractor engine. Just use one set of the points and take the other one off. Bottom line is the points are used to open and close the ground connection on the coil. If you know how to use an ohm meter, check the points and make sure they short to ground when the points are closed and don't short to ground when the points are open. Since I don't know how much you know about distributors, be sure that you set the gap to about .014 when the points rubbing block is on top of one of the 6 high spots on the dizzy cam lobe.
As said above. And when you install points put a little Molly lube on the cam lobe so the points don't wear fast. Actually, you normally put a dab of lube on the arm of the point that touches the dizzy lobe.
The best way to check if your points are gaped correctly is to check the dwell. You do this once it is running to verify the gap. I have one of those old Sears engine analyzers (had it since I was 25). It will check RPM and dwell. I was just tuning my 40 this past weekend. Adjusted the valves, checked the RPM and Dwell. Got it purring.
You set the points once the dizzy cam is on a high spot, which would open the points fully. If correctly set the points will only open the amount you set them with the feeler gauge and the points close fully once down off the high point on the dizzy lobe. I usually get them close as I can with the feeler gauge, then check the Dwell with my engine analyzer and if they need to be tweaked I will eye ball it. Some old American engines you could change the points setting while the engine was running, by using a flexible tool and working through a window in the distributor cap.
The points are closing to cause the coil to build a magnetic field, then the points open and the coil magnetic field collapses. The electricity wants to find the easiest path to ground. Sometimes when you grab the plug wire you are the easiest path to ground. The current from that collapsing field travels through the coil wire to the dizzy, where it then jumps the air gap of the rotor to the plug wire the rotor is pointing at when the points opened. The current then travels to the spark plug which is screwed into the engine head and again the electricity form the coil jumps the gap of the spark plug electrode to get to ground of the engine head, which causes the spark to ignite the fuel air mixture. It's all about timing.
Here is a good video describing Dwell....
Guessing your Mallory must be a vac advance type distributor. Have you added a vac advance port to your carb?
That’s probably not going to give him spark.
I used to have a Mallory dual point distributor on my Pontiac 389 that red lined at 7,000 RPM. I thought that it would for sure shave at least 0.2 seconds off my quarter mile ETs at the track, but it was no better than the stock distributor (even after playing with the advance curves on both). All it did was empty my wallet. The matching Mallory high performance coil burned out too. The only coil I have ever seen burn out.
My recollection is that you have to set the dwell on the leading point set and then the trailing one. It will run with only one point set.
A 389 that revs to 7000rpm - That’s not something you see everyday!
