Looking for help from the Sniper gurus... I'm an idiot, looking for guidance. So far @BenjaminCA 's idiots guide has not dropped to my level of idiocy.
I've been trying to get my 40 running for a few weeks now. It seems to crank fine, and it sputters now and then but won't fire and run. I can't get Mosely Motors (where I bought it) on the phone or email for help so hoping someone here has some input.
The kit Mosely sold me is plumbed like this:
He gave me that diagram to follow, which I did.
I have the pink wire on the sniper harness tapped into ignition under the dash by fuse box.
I have the 1979 coil and igniter with fj60 distributor. Double checked all of that wiring with Haynes diagrams and replaced the fusible link with a new one from
@Coolerman.
Yellow wire from sniper harness to negative on the coil as per instructions.
When cranking it the voltage drops to 10 ish and rpms are around 300. From what I understand the voltage needs to stay up at 12 and RMPS should be higher? Fuel pump is kicking on with ignition and builds pressure. When trying to start i can see fuel mist in the sniper.
A local guy that has worked on snipers was baffled an
Ignition Coil Driver Module wasn't included in the kit to regulate the voltage. I had called to ask him to fine tune it for me, but he's so busy he's not interested in working on old rigs. Any ideas? Is there a better spot to tap into ignition? Not sure what to try next.
