- Thread starter
- #341
Cheers!! Appreciate the info, I’ll give those a check,From experience on other cars, if it just clicks when attempting to start, it's usually from the motor to the chassis or battery.
I've figured out volt drops by doing the following:
My guess is it's the large guage main ground from the battery to the block is finger tight. On the cars I have seen with similar symptoms of interior lights/ accessories working but starter just clicks, it's been the block to battery or chassis ground. You probably at least had the firewall and block one off to do the head.
- Check voltage at the battery posts. As stated before, should be 12.5v or higher but regardless of what it is, this is your spec for the next check
- Check voltage at the cable itself. Compare to voltage from #1
- With your positive lead on the B+ post, put the negative lead on the fender ground bolt, then on the lifting hook on the head (or similar) The voltage should be the same or very very close to voltage at your posts from #1
As far as ground I did paint the lift hook on the head , maybe that’s effecting the ground. Just seems odd that I was starting and running fine now nothing... where is the large gauge main ground from the battery to block located?
