- Thread starter
- #361
That reading is with key OFF?Doors closed, except rear hAtch, I don’t think it has an alarms and no lights inside are on... radio turns on when the truck turns on
I appears to be the fuseable link side... drawing around 90That reading is with key OFF?
If so, then, reattach the battery cable and detach each of the fusible links to determine which circuit is drawing the juice.
Can’t really access the main crank bolt without pulling the fan and shroud...Just to be sure, can you turn the engine over by hand?
Never mind got a crescent up from the bottom, engine spins freely left and right, phewffJust to be sure, can you turn the engine over by hand?
Excellent. any chance you've got a spare battery to swap into this pig?Never mind got a crescent up from the bottom, engine spins freely left and right, phewff![]()
Man I wish, just tiny little things out of lawnmowers and jetskis... don’t think those will cut it..Excellent. any chance you've got a spare battery to swap into this pig?
There are (3) wires from the fusible link.I appears to be the fuseable link side... drawing around 90
View attachment 2531881View attachment 2531882
Sounds good will do and report back, thank you so much for the help!!There are (3) wires from the fusible link.
What I meant to say was, also attach the main part of the fusible link to the battery cable, then unhook each one separately, and check the draw across each of the separate wires. This will isolate which circuit of the three that is drawing the current. Then you know to look in the engine compartment, the interior or ?.
Ok so on the little black box the smaller 10mm link is drawing around 17 and the larger 12mm is around 80. The third wire with the connector is at 0There are (3) wires from the fusible link.
Holy heck... went to go do the light Test to see if they were dim.. forgot to plug in the drivers side when assembly last night in the haze of everthing. Just plugged them in and the truck started no problem. Sorry guysThis isn't an excessive draw problem, if it was, then putting your multimeter in line with the vehicle would blow the fuse in the meter instantly or melt it's cables. You are reading mA which is normal and would take weeks to drain a full battery.
You need to test the voltage AT the battery while attempting to use some power in the vehicle. Turn the head lights on. Do they come on? Are they bright or dim? Now, with them on measure the voltage on the lead part of the battery terminal, directly on the battery, NOT on the vehicle's hook up terminals. Note it. Now measure the voltage ON the terminals. Is there a big difference?
If not, if the lights are bright and voltage is the same on the battery as well as the terminal then try the same measurements but with turning the key on, ready to start, the point where you say everything is dim. Take the same two voltage measurements. If they are the same, test the voltage at the output side of each of the fusible links. Somewhere in this, you have a bad/loose/corroded connection (or two).
Yeah all it took... seemed oddYou plugged in the drivers side headlight and now the truck starts?
Ummmm. I think you bumped something that was loose. Most likely you still have a loose connection that will rear it's head again soon.
I had a cheap Gates in there previously and its out aswell, i tired it boiling and it was opening around the same as the new Toyota one i have..You should not drive around with engine temps that low for much. A test run or two won't hurt, but you won't even get overdrive enabled until things warm up properly.
If you think the Toyota one is opening at 190, go get a cheap aftermarket one to test against and see if they open at similar values. I thought the stock unit was a 180, but I'm not sure.
