Hydrolock- connectiong Rod
palisade,co
So blew a head gasket. Took it to local "guru" told him to pull pan-- he said oh you don't need to do that you can't bend a rod.
So finally finished and it smokes "guru' say something internal. He seems lost. But think piston is not round.
So feel free to kick in guys your toughs.
Seems that it would be more likely that coolant in the cylinder(s) washed the oil film off the wall and the rings have scored the cylinders. Pretty sure a bent rod would cause lots of different things other than oil burning.
I think I need more details before venturing an opinion.
What color is the smoke?
Oil pressure normal?
Any engine noise or vibration at speed that wasn’t there before?
You already know that I’m no great fan of your mechanic. But neither am I one to ‘rush to judgement.’
Ok I took it directly to a 70 year old mechanic. It did not smoke, maybe antifreeze in the muffler from the head-gasket?
Then he pressured check cooling system, all is well.
40 lbs oil pressure at start, 50 on the road. Runs solid. I plan to drive it and just watch it.
So not sure what the "local guru" was talking about. Most people use the word guru cause they can't spell charlatan...
I have to laugh, the Guru in Grand Junction Colorado, said that might be the issue. He was not sure.
Hell it was in his shop for 2 months! And not sure why it smokes....
