- Joined
- Dec 23, 2015
- Threads
- 34
- Messages
- 225
- Location
- Los Angeles, California
- Website
- charlesandhudson.com
I'm installing an OME heavy on my FJ62. Rust isn't an issue and everything came off ok. Got the leaf spring shackles and pins in and tightened down, but when I use the jack to compress the spring to line up the bottom plate to the U bolts, they are off. I was able to get one side to go through but the center pin won't line up. The other side I can't even get the ubolts to fit around the springs. It's off by about 1/2 inch.
Then I noticed the bump stop isn't lined up to the axle where it should be. Looks like the entire axle shifted forward a bit. I'm not sure how to get it aligned again so the bolts slide in smoothly and also get the axle lined back up properly underneath the bump stops.
I've got four jack stands and one floor jack. I've had the jack stands under the frame and also supporting the axle and different times.
I had to put the tires back for now and it's currently resting on the bumpstop on one side for sure.
Any help is appreciated before I call it a day and have it towed to the shop. Thanks.
