How do i install the window felt?
Alabama
Ok got the oem replacements from cdan. Window channels easy, 1st window felt easy, 2nd window felt impossible:mad: . It seems like the glass is in the way. So, do i need to remove the glass, if so how?
To late now, but the 82-84 rubber ones are much nicer........
no you do not need to remove the glass. check to see if anything is cloggin it up in the channel.
i remember that mine had some felt jummbled up down there
Maybe I'm mistaken, but I think he's talking about the felt strips that go where you rest your elbow? :confused:
I just did this, and if these are the felts you're talking about I think it would be easier if you unbolt the bottom of the glass from the regulator and lower the glass down further into the door. At least that's how I did mine.
Jeff
Badass;
See Manual #98154, page 11-28. U can do this with the glass in place; just need some nice thin, smooth blade to help guide the felt into place.
With that said; u can unbolt the window glass at the bottom. First, stuff a large rag below glass and regulator area; then unbolt glass rail and carefully allow the glass to drop onto the rag. This will allow easier access to the felt install area.
Jeff
Badass;
x3. I did it this way with the factory felt. It doesn't seem possible without removing/relocating glass because the metal tabs on the felt strip stick out too far.
Actually if what you are trying to replace are the wipers (part your elbow rests on, (inside is a felt and the outside is a rubber seal) you can unscrew the window bumper on the bottom of the door. It should allow you to lower the glass enough to get to the spring retaining clips and retaining bar. That is what I did on the 73. Thanks Mark A.
Jeff
Bam!! Yes, never thought of that, just lower the glass. THanks!!!!
