How can I figure out why I have death wobble?
bjp
Los Angeles, CA
I have a 1993 with death wobble that I've tried to fix and it's still not fully gone. I'm sure there are many things I could blindly try if I had infinite money, but how can I figure out which one is actually likely to fix the issue?
I know this is a bit long, so to encourage responses: I'd be excited to send $50 to whomever first describes a diagnostic procedure which leads to diagnosing an issue that, when fixed, solves the problem. Just throwing out things it could be doesn't count unless accompanied by some test I can perform to confirm or deny whether that thing is actually the main problem before spending money and time addressing it.
When it started
I'm completely new to Land Cruisers and vehicle maintenance in general. I bought this LC in March with 163k miles and I've been baselining it ever since, so I've put less than 1k miles on it. I thought I had the minimum set of stuff done in September so I took it to an offroad picnic about an hour away by paved roads. Just before hitting dirt, I got my first death wobble around 30 mph. I thought "that was crazy", but the pavement was a little rough and I hadn't heard about death wobble before, so I did a bit of light offroading then started home. A fire forced me to take (paved) back roads for 23 miles and I got probably 8 or 9 wobbles. By the end, I was trying to intentionally trigger them to figure out what the trigger was, and I was trying various things to mitigate them instead of just braking hard, but I couldn't find any reliable patterns.
Behavior
The wobbles always started between ~20 and ~55 mph -- I took it carefully on the freeway on the way home after the wobbles on the back roads and got zero wobbles on 28 miles of freeway, then one more wobble on the 1.5 miles between the freeway and my house. The wobbles seem to be more likely to happen while on a slight curve (especially when the curve direction changes), when hitting small bumps (but larger bumps don't seem to do it), and when slightly braking, but even a combination of all these factors doesn't guarantee a wobble, and not all factors are necessary to produce a wobble. Again, I could never figure out when they would or wouldn't happen.
Initial investigation
When I got home, I found the jam nut of my front adjustable panhard rod completely disengaged, so I tightened that jam nut. I could grab the drag link or tie rod and rotate them on their axis by hand fairly easily, but I didn't feel any play. I jacked up each front wheel one at a time and tried to wiggle the wheel while grabbing at 12 and 6 and I didn't feel any play. I tried to wiggle while grabbing at 3 and 9 and did turn the wheels a bit, but didn't notice any play. I took off the mud guard of the driver front wheel and looked at the frame and panhard tower around the steering box and didn't see any cracks. I measured 30.15 PSI in front passenger tire and 30.65 PSI in front driver tire, and both wheels still had balancing weights attached (though I can't rule out some falling off). The two of four knuckle nuts I could easily access with my torque wrench were still torqued to at least 71 ft-lbs and the other two were "tight" (both sides).
After tightening the panhard jam nut, I took it back out on a 45mph street and got 2 more wobbles within 3 miles. A member of my offroad club diagnosed needing new rod ends.
Attempted fixes
I bought the Trail Gear Heavy Duty Steering Kit which includes a new drag link, tie rod, 4 rod ends, and a steering damper. I took off both rods, damper, and the steering box and had the steering box professionally rebuilt. The old steering damper was pretty much entirely done -- spring only, virtually no oil resistance. When reinstalling the steering box, I replaced the high pressure hose with Gates and the low pressure hoses with Gates from phhkit.com. I installed the new tie rod and used two aluminum angles to set 1/8" toe in at 37" wheel diameter, using two laser pointers to center the steering:
AM-JKLV3AsFfm_f_Aep2X7zeCWn3oG4E3Uj6J8k4gFzTSp86yaOr5vxQTSbEwRRchurt5SAQ106R7kd5BSI3YmZnXX08ITylryWDto_gtg9QffLKqVvY2SlYRavUIjidNBMNznuW47E73VtCN3zpOFDlGflNjQ=w2614-h1960-no
AM-JKLWJzV7fI1riqlhFv63N5t3tIcehExPze8gRz2hdGgp4k3flGlsPX238QlwBvm3pn3sdkD8uZweR19cAihRmaC1AauEKR1ssd2q4ytYQMoFTHkeKNFrsho3NDVp3BIi9ZoMXnP9PWyc-CwUQHmg_7_z4Gg=w2614-h1960-no
AM-JKLX_NWUZ3X4xIMoJtsIW0m4UzD76wFN2qmzhCvOpPsqmu8zh1aVds2ncGKpXdwUjtMhuGtyHVpVLmyV7XIN0RfGsFwN3vSbwa5Q5lfsvMjQXCWHmbRg_M4TPTSbNQTcoPeQJAXf1NlA8eDwQ8anib9_TGw=w2614-h1960-no
AM-JKLV1UDQuTrv9VWAKorOawU7FmIvASj3OLKrSVSZJCrVJZk1qx-mIcJcAD27STOYL-6bs0RDOxud-CwF85ugeOKuyknlk7hgVFbF8PEQDQ7Fm7vEHxkeErEXafkFDy8KjpT89Hj_gyRmt0T9B5Z2nLCp2nA=w2614-h1960-no
AM-JKLVzqvAdly8XmG6k6WZlyebu-4Mf4S3OMUq710EJ23p7en8czy9OzM9QDlG3oxreue87377VoVbPlOiO2w0mjY7hqWtsBMd7WYAXnQzMrHt_Wm59JAjWveZnjC0aMa_CZP2L-tLm2yiubJMragdQaRTgjg=w2614-h1960-no
AM-JKLXSs77TR621Ruxhqg19VJfm7jJFI14QNHnOfzM38XMxDrnGDBHFCktUdd1OeCcpQlqECBp_6YNlunCWQddMjzIjUJfnEhegMB0lyqPHTupGRlh_m2r1PR215x95C5WMZFJeetwZhnMZnQItkZTeFyVmJQ=w2614-h1960-no
AM-JKLX_zmytYQ20veC3SdlYiQ47tYZKVwXiU1icT1efQwpAalCvQCHfVro13AbeoxJbCYMJEDbpi-BD_jGdLHZBKM8oMDwpubeVk4Z4hi76IBAoA13efwBmCCQ7XCnJ-WgW1JXIeXrP9xY9ttcjt4BYR8UneA=w2614-h1960-no
I installed the new drag link and tried to center the steering wheel as closely as possible using the two laser pointers on my alignment jig shown above. All crown nuts torqued to 67 ft-lbs plus whatever was needed to line up the cotter pin holes. The Trail Gear rods use jam nuts and do not have any indents to put a wrench on (!), so I tightened the tie rod jam nuts to TG's recommendation of 75-85 ft-lbs using a giant 14" set of vice grips and a giant adjustable wrench. I tightened the drag link jam nuts with just the wrench to "medium tight" because I knew I would need to adjust the steering wheel position a bit more. I did NOT install the new steering damper because one of the bolts was missing and Trail Gear has STILL today not delivered that missing bolt (they blame PROcomp, the steering damper manufacturer), but my understanding (which could definitely be wrong!) was that the steering damper just masks the issue and is never the root cause, so it seemed ok to leave it out initially. I also got my front wheels professionally balanced. Unrelated(?) to these fixes, I also installed a new Tom Woods DC front driveshaft.
Results
After these fixes, I drove a 38 mile loop including 23 miles of paved mountain roads like the ones that triggered so many wobbles. Zero wobbles. I did feel some "incipient shimmies" (vibrations like the ones that preceded death wobbles) which worried me a little, but I don't know the truck super well so I figured those may just be normal solid axle stuff. Given that I got 2 wobbles in 3 miles before the fixes, I thought for sure I would see wobbles in the big circuit if they were still a problem. The drag link did come loose from its jam nuts during the circuit because I hadn't done the final tightening yet, but even with the drag link working its way loose, still no wobbles. So, I considered the issue probably fixed and moved onto the next work.
Going to the picnic, I also had the AC shut off from overtemp while climbing a steep freeway grade on a hot day, so I did a bunch of cooling work next including replacing all of the heater hoses, replacing thermostat, replacing fan clutch with new 95F/6500cst-modded clutch, replacing radiator, and adding a temperature sensor to the upper radiator hose.
I went to do a short test drive to also re-set the drag link properly and...got a death wobble a short distance before my house. Well crap. I finished dialing in the drag link length and tightened the jam nuts to basically the gripping limit of the vice grips, then drove the same 38 mile loop. No death wobbles, but still a bunch of "incipient shimmies".
So, I don't really know what to do. I don't think tightening the drag link jam nuts should have made the difference between wobble and no wobble since I wasn't getting wobble on the big circuit even when the drag link was loose. But, it's also now apparently hard to actually reproduce the wobble. I feel like I can't take the LC on trips because I'll probably see wobble at some point since it was still present after all the fixes (not taking it on the trip I'm leaving for today because of this).
Configuration
When I bought the LC, it already had:
  • 37" Cooper Discoverer STT Pro tires with most of their tread life remaining
  • Method 105 beadlock wheels
  • OME 419 Comp Coils in front, unknown OME coils in back, resulting in ~5" lift based on DeltaVS's panhard bolt method when lightly loaded (but still have front & rear bumpers + winch on front + full-size spare on back)
  • Front sway bar removed
  • 5.29 diff gears (net result from 37" tires + 5.29 gears = truck travels 92% as far as speedometer/odometer thinks it went, so slightly lower gearing than stock)
  • Air locker front, Detroit locker rear
Not very many miles before the picnic, I installed new DeltaVS radius arms for a 4" lift. I tried to get before & after caster numbers, but no shop around here will measure alignment on beadlock wheels, and I gave up trying to measure the caster accurately.
I had recently removed all wheels (one at a time), deflated, carefully and progressively torqued all 120 beadlock bolts, reinflated, and reinstalled.
Both the previous owner and the one before that are members of my offroad group (I joined shortly after getting this truck). The previous owner had a bunch of stuff put on the truck (including air locker), but drove it only a few hundred miles over 2 years. The second-previous owner (an experienced amateur mechanic) said the front axle "is basically all new" -- he said he thought he did the rebuild at 13Xk, but based on CarFax, I don't think he owned it until 145k (he works on a lot of cars, so not surprising his memory may not be perfect).
Possible things to try
I can think of a number of things that hypothetically might address the issue:
  1. New non-beadlock wheels + new smaller (35"?) tires
  2. Knuckle rebuild, including new wheel bearings
  3. Install steering damper
  4. Add a front sway bar
  5. Replace some of the front axle components (not sure which ones)
I'd be happy to do any of these to fix the issue, but doing all of them would be very expensive, especially when it seems like there's no guarantee that even doing all of these things would fix it. #2 seems like the leading candidate to address any wheel bearing problems, but it seems like the fact that there's no play in the wheels wiggling at 12 and 6 would suggest that the wheel bearings aren't the issue (plus, the wheel bearings were probably replaced 20k ago). #3 will probably "help", but if it were just hiding the underlying issue, that seems like it would actually make things worse by making the underlying problem harder to find. Could #4 actually affect death wobble? I'm not sure what I would be targeting in #5; are there any components that might be causing the wobble? #1 seems like the most likely solution (but I don't really know what I'm talking about yet), but $3k-$4k is awfully steep for "most likely". I want to get non-beadlock wheels eventually in any case, but I really like the Coopers and would like to keep 37s if I can figure out this death wobble issue.
Thanks for reading; thoughts?
If you're heading out for a trip imminently, here are a couple others to check and/or complete:
-get your tires balanced on a road force / dynamic balancer. If you've got a tire failing it'll show as imbalance and can cause DW. This balancing method will show that failure if it exists.
-you mentioned tie rods, but not drag link. check your drag link ends, too.
Good points. My Discount Tires and probably all of them in my town have a road force balancer roller attached to their balancing machine. Each tires get balanced both ways and I was there this morning getting this done. Trouble is, I threw all the rim weights as soon as I hit the hwy so I'll be back this pm :bang:
The store manager was there with me and all tires balanced out fine except one tire that had to be dismounted and rotated 180deg. I still have DW as soon I hit near 50mph on my way into work after leaving DT.
Good call on the drag link, I'll check that too.
I am also experiencing a wobble. My wobble is at 50, just made an appointment with Discount Tire for a road force balance. Will update after the appointment.
To be sure a tire is balanced correctly, have the tech loosen the holddown nut, rotate the tire a bit on the balancer shaft, re-tighten the nut and run it again. It is difficult to mount a heavy tire/wheel correctly, and this method will determine if your tech is doing it right. If he isn't , he's balancing a wheel that is not centered on the machine, so it won't be balanced when it's mounted on your truck.
Rim weights come in many different styles, made for different styles of wheels. If the wrong ones are used, they will fly off. The correct weights, installed correctly, rarely fly off. If the tech doesn't know this, he probably isn't knowledgeable enough to get the balance right either.
If balancing your tires cures the problem, most likely you don’t have death wobble but rather a harmonic tire balance problem, although you could have both. Death wobble is the side to side harmonic oscillation of the wheels which you will not mistake for a tire balance problem once you have actually experienced It.
Nah much funner to by into fear mongering and make everything related to a death wobble.
I went and got my tires balanced today. The fronts checked out, the rears were a little off and the drivers rear wheel is bent, guess it is a good thing I have a matching spare.
I will crawl under the car again and double check everything and go over the pan hard frame mount with a fine tooth comb and check for cracks.
I have without any doubt had death wobble that was fixed by balancing the tires. On several occasions. Unless death wobble is something other than the steering wheel (and truck) violently and uncontrollably shaking back and forth. I'm confident I can induce death wobble on my truck at will by adding wheel weights to one side of a front wheel. Come on over and you can be the judge if it's death wobble or not.
Here's a story that may help someone struggling to find death wobble source.
I had what I thought was a subtle shimmy when braking slowly from highway speeds down to 30 mph and thought perhaps it was beginning of warped rotors; existed that way for over a year; no issues.
Then I decided to upgrade to billet lower control arms for a 3 to 4" lift with OEM bushings. As soon as I did that, I got noticeable death wobble between 40 and 45 mph. I proceeded to put fresh OEM panhard bushings in to eliminate that as a source; did nothing.
I then had my 33" tires rotated and road force balanced and even told them I was experiencing death wobble; they said the tires still had life left and they were balanced perfectly; swapping the rear tires to the front made no difference; still had same death wobble and it seemed to be getting worse too.
I took it to an experienced 80-series shop and they did a test drive and alignment check. Diagnosis was no observable reason for the death wobble. However, my caster was at + 6 degrees, but my toe was fine. He said the caster might be the issue.
I then remembered I had Slee + 3 degree offset wheel bearings in the front axle that were installed about 100k miles ago. So, I told them to do a full front axle refresh and use standard wheel bearings.
After the front axle refresh, the death wobble was much more muted, but I could still feel a bit of a light shake in the steering wheel.
Next, since I was going to go through and replace all bushings with OEM, I removed my front swaybar to swap them out; I ended-up driving my rig several times without the front swaybar and the death wobble came back with a vengeance.
Well my swaybar parts were delayed and I was getting fed-up so I decided I'd just bite the bullet and get new tires to rule that out as well.
Bingo! As soon as the tires went on, even without the swaybar, the death wobble went away for good.
Moral of the story here is:
1) Even if you've had your tires road force balanced, that does not mean that you can't get vibrations from them at certain speeds; that one screwed with me because I though I had ruled it out.
2) Death wobble can have more than one contributing factor. I believe I did have some looseness in my axle somewhere that was contributing partially to the "warped brake rotor" feel when doing stops from higher speeds; that is why the death wobble seemed somewhat improved although not completely gone after the axle refresh.
You can find your death wobble source if you look in all the right places; keep at it!
Great post, thank you for talking the time.
I previously experienced some "resonance vibration" for lack better term in my 80 that went away with alignment and new tires.
But also experienced true DEATH WOBBLE in a Jeep WJ that was absolutely insane and felt like the vehicle would literally disintegrate. That required a complete front end re-do with new track bar, steering stabilizer etc.
My old LX450 had a similar issue that pressing in new radius arm bushings- 2 were definitely suspicious (the 2 at the RR-most where it mounts the axle shell to the body)
No saying it’s always those, but my wobble flat was gone with all 6 new bushings in the radius arms.
I had just over 260K on the powertrain, and an unknown miles on a 4” lift done up on the axle end / camber correction & whatever brand those turquoise color springs are/were circa 2010.
Mine also had death wobble. Would kick in typically between 35-50mph and while coasting or light braking / acceleration, and at the same time slightly turning. Was shocking when I initially experienced it, but controllable once I got used to it - hold the steering wheel tight and get out of this particular load / turn situation. I drove it circa 5k miles with this condition.
It didn't go away after fixing various suspension issues (shot bushings, very wide 2" spacers, axles not centered, worn out tie rod ends, etc pp). I also confirmed caster angle is reasonable (3.5" lift + radius arm flip mod in the front).
What fixed it for me as well are new tires. I don't think the brand mattered - the old ones were just really worn out. Next to not having much profile left, there were both large chunks missing from the profile (rocks ate it away), as well as the whole profile wasn't round. I.e. some patches had 1-2mm more profile left than others. So overall they were neither round nor balanced.
Next to death wobble, the whole rig would also vibrate significantly when going >70mph. How much exactly varied from day to day - I assume whenever I took it offroad, the blance/roundness would change somewhat because rubber from different locations would fly / rub off. I hope the new ones are more resistant to this. At least for now, it's driving amazing - the first time I can go 80mph without being scared that everything will fly apart in a second ;-)
The middle one shows the old tire, the right one is the new one (the one on the car is the spare). Note that all have the nominally same size of 37x12.5R17, but the new one is nearly 2" taller.
Side view - this one had a bit more profile left, but you can also see how destroyed it is. Large chunks missing from the lugs. These tires had a hard life, being driven >50% off road as far as I know.
New set of 37s Patagonia was about $1,700 in total 🙈 Hope they'll last for a while!
