How bad are my birfields leaking?
Austin, TX
Newbie here looking for an opinon on my birfields
'97 LX450 relatively new to me, currently with 115K miles. Last recorded service of the birrfields was by dealership in 2004 at 50K miles.
I don't actually see anything dripping, would you all consider these leaking badly? If so, how long can I put this service off?
I would like to tackle it this fall, it has been hovering around 100 degrees for almost a month here in Austin!
I just serviced the differentials but did not really pay attention to the fluid characteristics, iirc just looked kinda dark but consistency was not weird.
If I just add grease through the observation hole can I prolong this until winter? 5000 miles? or is that unreasonable?
thanks,
scott
PS I do need new front pads.....
Seen worse. If it does not leave drips overnight, I would run it and check periodically. Any clicking noise or bearing noise? If not I would run it and watch it.
Check to see if your diff breathers are clog free.
They look a little low on grease. Put in a bunch of pumps of moly grease (such as Valvoline Palladium through the square plug hole on the top front of the knuckle. Do about 50 pumps per side(around 1/2 tube).
Make sure to check your diff oil level on the front plug. Fill with 80W-90 gear oil as necessary until it runs out the hole with truck level.
Your location says your in Austin, Land Cruiser Specialists are in your area and they do a great job for not too high of a price! I had mine done there since I had no time to do it myself while I'm in school.
I'd clean them off at a DIY car wash place and see how they look after a few weeks of driving. At the same time I'd check the torque on the knuckle studs (once clean).
Topping up the moly grease and cleaning/replacing the breather as mentioned by others is a good idea as well.
You'll likely need to service them at some point but it doesn't look imminent.
The spots on the tire look like gear oil. If the grease smells like 90w then the axle seal is leaking
Your rim & inner tire sidewall aren’t a spin-art of slung grease/soup.
So either not bad really, or like mentioned - dip the knuckles via the pipe plug, see if you’re rolling on low, low grease levels.
But just by the pics, I’d say the threat level is lower-ish at most.
Lotsa guys call way worse a normal Tuesday.
Squirt a little fresh grease in the hole and do a full knuckle service at your leisure when the weather is nice :) @cruiseroutfit for the rebuild kit. Just by the minor soupiness (is that a word?) I would say your inner axle seals are letting a little oil through. No biggie, just another item for the to-do list.
x2, put it on your agenda in the next few months.
Let us know if we can help with a knuckle overhaul kit @ Cruiser Outfitters. We stock full Japanese overhaul kits with or without wheel bearings and any tools/parts you might need to do the job too. Buy a few rolls of paper towels and a box of gloves. The worst part (imo) is the cleaning process.
Do what a lot of us have done - buy an overhaul kit from @cruiseroutfit and then let it sit on the garage shelf for a few months until you are ready. I like to think through projects like this in advance so I have everything I need and don't need to stop when I'm elbow deep in grease to go to the parts store.
Not a 100% complete list for the front axle job but you get the idea. I also recommend a seal puller which is not on this list.
Guys, thanks you all so much for jumping in, I think I have a plan and a very good idea of what needs to be done! I replaced the master cylinder last weekend and have all my tune up parts planned for this weekend. WIll ad the palladium moly grease I just ordered and will replace my diff breather with an extension and new brake pads - the birf service will wait until cooler days.
Thanks and happy trails.
Scott
PS awesome to have that parts list!
I smeared a bit of anti-spatter paste on the threads, built-up weld in the center of the bolt and welded a hex wrench on to turn it out.
Nothing like a MIG in the garage. That & a plasma. 🍺
Mine were leaking bad so I had them serviced. now they are clicking when I make sharp turns. What is causing that?
You have worn out birfs, bank on it.
You **could** flop them side-to-side as a band-aid, and you’ll alleviate the sound while you start saving dimes in the piggy bank for a new set.
Search clicking birfs, you’ll get plenty of results.
probably worn birfields are causing the clicking. how long ago were they serviced?
It may be that the shop didn't pack enough grease into them or the knuckles when serviced. Need to check that.
