if the system doesn’t know the vehicle is moving ie no front wheel speed input - then the adaptive variable suspension stays in its quiescent state regardless
Understood, thank you Sir. So if anything is changed to override the speed input wires, adding a switch is better than just cutting wires but doing nothing at all is best.
Yes, doesn’t matter if you’re using the previously available “name brand” override switch or sticking in a $2 DPST switch inline or cutting wires - if the system doesn’t know the vehicle is moving ie no front wheel speed input - then the adaptive variable suspension stays in its quiescent state regardless
Adjusting your AHC sensors are fairly easy :)banana: job). You'll need to furnish/fabricate a simple bracket extension which I'll cover in step 5. You'll also need one can of AHC fluid from Toyota $22/can. (part # 08886-01805). I have heard the exact fluid costs more if bought from Lexus. 1...
It's the vid done by the original author of this thead. It's a method used to trick the AHC height control system from automatically going to neutral from high when traveling over 20 mph by cutting the signal from the left and right front wheel sensors to the AHC ECU. I learned that i was traveling a well worn path rather than blazing one.
So, I reconnected the wires that I cut, left the neg lead disconnected for a couple hours and came back. Still no go. I get 2 blinks then back to solid green N. Had my son hit the switch while I listened at the pump and it didn't seem to be coming on. I've checked the AHC fuse and it's good. Haven't checked the relay yet (don't know how to check it, but I'll google it). Does anyone have any other ideas?
From N height with truck running in park press the raise button. After a couple seconds and seeing the H light blink press the suspension off button and shut the truck ignition off. If you get the timing right when you restart the truck will be locked in High. It will stay there until you exceed 50 mph.
So turn off before going all the way up? And it will be in all the way up in H when cranking again? I think I saw where others tried this with no luck. Are you riding a unicorn?
I'm guessing one of the primary reasons the system lowers at 19 mph is due to the excessive angles put on the CV joints. So if you drive like this very often expect to be buying new CV joints real soon.
Press OFF while still blinking before H is solid. I tried it when all the way up and it didn't work. So I just allowed it to blink for three seconds then pressed OFF and turned engine off. That seems to work every time.
