- Thread starter
- #41
I've seen pictures of these for about a couple of years now. But yours is the first time I've seen someone actually make one.
I think you need to revise the title. Homebrew to me conjours up visions of almost undrinkable, foul smelling liquid. Not the piece of artwork you've got there.
$3k is about what an aluminium fab shop would need to charge for such a thing.
I found them by accident while looking on the net for someone to ceramic coat my headers, the same place did intercoolers using these cores.
Though the Laminova set up seems to use up to 4 cores but in series so each core works less efficently than the first, by the time the water has reached the 4th core it's already had to absorbe the heat from the first three.
My set up runs all 4 in parallel this however requires a bigger water pump as each core requires 20lts per min minimum. I have on order a Davies Craig EWP110 http://www.daviescraig.com.au/documents/EWP/EWP110_Brochure.pdf
The other draw back to my set up is the number of coolant lines, though this I have a solution too I think.
My only disapointment is the lack of information I have been able to find on the net. Air to Air to me is not suitable for our application as we never achive the speeds to make use of that kind of intercooler efficiently. Water to air seems much more usable but when you start to look at what's available it's pretty limited and expencive. The ricers are well covered by Air to Air, it is at the end of the day a pretty cheap solution. Water to air requires pumps, radiators, thermo fans on top of the cost of the intercooler. The pump alone is $250, plus the cores and Aluminum say $250, welding $180 with still a radiator and thermo fan to go as well as piping. Overall I would say total cost is around $1000 by the time I'm done. Still by far cheaper than the quote for the intercooler alone though.
So this could be a fine home brew of great distinction that out shins it mass produced competitors, on the other hand it could as you say be undrinkable and foul smeeling gut rot. Time and testing will tell.
Either way I have had a ball designing this from scratch to building and soon testing it for my up coming 2F-ETI
