I’ll 3rd/4th? the recommendation to go to disc brakes
unless you’re absolutely going for a stock restoration.
I’ve been working on this “tech guide” on the disc brake conversion parts you need to source. There are some fantastic conversion step by step guides here on Mud, this guide is aimed solely at helping you find the donor parts for a disc brake conversion:
Skip anything that has you reusing course spline birfield outer axle and uses adapters to fit GM calipers and rotors. Like hard pass skip. These require you to re-use your course spline (low strength) outer birf joint and free-wheel hubs, both of which have no options for upgrades. If you have a...
forum.ih8mud.com
