And now the half doors. Last summer I found a guy selling some parts in Edmonton so I bought a set of doors off of him. I think I paid $150 for them and they are in pretty good shape. They are from a '74, but he had them on a later model and I like the earlier style so I bought them.
When I got the doors, I never realized that some '74's had door panels. I thought that these were some PO hack and promptly ripped them off since they had been outside for many years. I have since learned that they are factory panels, and guess that a PO just recovered them. At any rate, I still have the metal trim pieces to hold the panels in place.
But anyway, since they are the older style, the tops can be detached from the bottoms, so that is what I have done for now. I had an extra mirror so I drilled a few holes and bolted it on. Should have paid a bit more attention, because the first time I ended up having the holes on some internal members and it did not work out so I had to drill another set. No big deal since there is still lots of work to do on the doors. Just a few more holes to fill when the time comes. Might get a set of mirrors that mount to the body to make it easier to switch between doors.
Not sure how to finish them at this point. I'd like them to have some curve, but that make is complicated. Just using angles makes it simpler to do, but I don't like the look as much, so for now they will stay as they are. I also want the insides to look good too and I think that will be hard since there are so many raised and indented sections.
The striker on my truck did not work with the latch from the earlier doors. I found though that the latch from the door did line up to where the striker was on the truck, so I decided to make a couple for the new doors. The first one I made, worked, but it was a lot of work to make and the bottom bolt got in the way so I could only use the upper bolt. The second one worked better but was also a bit of a pain getting the holes in the right place and the bolts were also getting in the way a bit. You can see in the photo below how I had to elongate the holes in order to get them aligned correctly.
So of course AFTER I have both strikers made, and not really happy with them, I come up with a brilliant idea. I figure I could take one of my strikers to the parts yard and see if I can find a Yota that has the same hole alignment and then I would at least have the holes in the right place and then I could use the flush-mount screws as well. Got some strikers off of a Yota minivan and they line up with what I have on the 45. The result is much better. Just cut off the original striker so that all I had left was the plate and then welded on a piece of steel and ground it down to have a a bit of a radius to guide the latch. Voila! Much better.
Left is what I started with, right is what it ended up being.
And since I had the doors off...
I think this is the best way to drive. I just have to get a body mounted mirror.
