Long time, no update!
Well it's time to get the 45 out of hibernation. This spring is much better than last year and I have been able to persuade the princess out of the garage already.
I stated to work on my PRO winch and thought I had found a solution to my short shaft issue (insert jokes here). One day it just came to me that all I had to do was create a bolt-on spacer with flanges on each end. I had a pinioin flange from something and it turns out that it was about half the length I needed. It was 2.25" and I needed to make up 5" so I decided I would get another one and weld them together and create my spacer. The result is below.
You might notice that it is not fully welded. Well, that's because I wanted to test it first before I got past the point of no return.
It turns out I'm screwed!
This is what happened when I tried to test fit it all.
My PTO shaft hits the exhaust. So I think that is the end of putting the winch on my truck. Now before anyone tells me just to cut the exhaust and re-route it: That ain't gonna happen.
So, I am very disappointed to say the least. I guess the only option now is to get another cruiser I am willing to hack up and mount the winch on it.
The other goals this summer are to finally change out my rear springs and shackles and to work on my half doors. I should be able to get that done if I don't have a major breakdown like last year.
I sandblasted my donor doors last year at our little sandblasting event ad now I'm just trying to figure out the best shape to cut them in and the best way to cap off the top once I do cut them.
