Help - Synthetic Fluid Trany/Engine
Loxahatchee, FL U.S.A.
Good Day All
I want to replace my fluids with synthetic.
FZJ80 runs awsome but engine does consume some oil.
Is synthetic oil a better option?
Any negatives to using synthetic oils for tranny and engine.
Thanks in advance.
IMO the only downside to a synthetic is the price and that is only an issue if it leads to longer change intervals.
FWIW I've never seen a synthetic that wasn't pour in compatible with dino oils.
I use Mobile 1 in every application where I can but for grease you should check what needs moly and what doesn't and make sure to use the right stuff.
Only real disadvantage to synthetic is cost. I run Mobile 1 15-50 and change it every 10,000 miles. I have to add a quart at 5000. I run conventional transmission fluid and replace 1 gallon at each oil change. Your results may vary. There are a million different opinions on lubricants. John
I also try to use a Mobil 1 synthetic in most of my vehicles, but I've found that for some reason Delo 400 is the best for high mileage motors that are burning a lot of oil between changes.
The PO of my 80 was pouring in more than a quart per week (700 miles). I switched over to Delo and put about 2500 miles on it so far with no additional oil needed. It was puffing blue smoke badly after sitting at a red light. Now it only puffs for a few seconds when cold started.
I had an old Ford that would consume every oil I put in it, until I tried the Delo. It may not be the best oil, but for some reason it doesn't burn off as easily. Wally world carries it in 2.5 gallon jugs for a fair price.
I personally wouldn't make the switch from dino to synthetic on an engine with a lot of miles :meh:
Sure, synthetic is without a doubt better oil, however, it does come at a cost, not to mention the tendency to create leaks by cleaning out what the dino is essentially holding together :doh:
Longer intervals really isn't an issue with the 1FZ as they're extremely easy on oil when it comes to contaminants :hmm:
Here's my Blackstone report using Toyota conventional 10w-30 (bottled by Exxon/Mobil) changed at 10,600 miles
They actually suggested that I run 12,000 mile intervals using that oil :)
For my last sample, I ran it up to 19.021 miles and it still had plenty of life with a 3.1 TBN reading :cool:
With these kind of results from conventional oil, I don't see the need to spend more on synthetic, especially when it can possibly create leaks on my leak free rig :meh:
My rig currently has over 400,xxx miles (original everything including HG) with over 10,xxx on the current interval and I plan on sending in another sample as soon as I drive her back down to Orlando.
Now, on a brand new engine, I have no issues using synthetic after a proper break in with conventional :smokin:
I use Delo on my hotrod and Road Runner :)
Excellent cheap oil and quite possibly the best conventional oil on the shelf
I agree with @98 SNAKE EATER. I switched to synthetic about 6-7 years ago. I had some minor leaks prior to changing. Could literally see the synthetic dripping out after running it for a week or so. I dumped the synthetic and went back to conventional 5w-30.
FWIW, I don't even change my own oil anymore. I take it to the Toyota dealership. They charge me $20.99 to change my oil with a new filter and grease everything while it's there. I can't buy the oil for that price. Plus they have free cookies. :flipoff2:
As for tranny fluid I use Amsoil synthetic. I change it once per year. It's actually nearly impossible to change it all out completely. I just dump what I can (4 qts) and add the same amount back in (4 qts). It always comes out clean as a whistle. There are some that will say you never need to change your transmission fluid, I am not one of them. Am I overkill? Probably.
Diff fluid I use cheap diff fluid and change it twice per year.
As for mileage I put about 3-5k miles on my 80 per year now but used to put more on it. It has 235k on it and have owned it since new.
If you've been running conventional oil it would be unwise to change now. If you have been running synthetic since the day it left the showroom floor then go ahead. However if you're not the first owner and can't verify the history of oil use keep running conventional motor oil.
Reason: synthetic oils can run the same weight as a conventional, however the viscosity is different overall. The synthetic will protect and lube like a conventional but is much more fluid and has a tendency to slip past worn seals sunstantially easier. Conventional oil is thicker and stays within the seals if you have always used conventional. Some people notice an oil loss when switching from conventional to synthetic which is usually a loss from the front or rear main seals or slipping past valve stem seals a little at a time and being combusted without showing any noticeable signs like blue smoke.
I hope this is not stealing the thread, and apologize upfront, but felt the question is relevant. If you have no idea what has been used, can a company like "Blackstone" or others analize and tell you what is in there? I bought an 80 with 185k and have not changed the oil yet, not sure what was used and would like to continue using whats in there. It doesn't leak a drop.
Yes they can.
Actually, they won't be able to tell you if your sample is synthetic or not as they don't test the base stock of the oil :meh:
All they can do is tell you the viscosity, levels of the elements and possibly compare them to the virgin samples they have on file to see what's the closest match :hmm:
That being said, I wouldn't put too much thought into it :redface:
Just choose any conventional oil off the shelf and stick with the same brand for the life of the engine :smokin:
This thread got me thinking. A couple times in the last few days on startup I thought I smelled oil burning. Until now I didn't connect that oil smell with the fact that I switched to Shell T6 synthetic about a month ago. I wonder if the oil is now getting past one seal or another and getting burned. I'm gonna have to pay more attention when I start the truck. I really hope I don't have to dump out umpteen quarts of fresh oil with less than 500 miles on it.
Good Day All
Thanks in advance.
Don't over-think it. Just pick your favorite synthetic, if that's what you want, and put it in. Then go drive and have fun.
These are tractor motors, not highly tuned race engines. Put what you want in it and drive. Synthetic is great and is what I run but totally unnecessary.
