it could also be a mish mash of parts
large bolt pattern or small?
vented backing plates are 62 series
the housing would have been changed as the original housing would have had the inner axle bushing not a seal
Don’t the spring hangars need to be moved outward for a full 60/62 axle swap? If so and your hangars are stock, I’d assume disc swap onto stock axle or a newer (non ball/claw) 40 axle was installed with that disc brake swap.
The studs and nuts holding the steering arm to the top of the knuckle. Larger pattern would indicate 79+ FJ40, Mini-truck or 60 series. Smaller would be 76 - 78 FJ40.That's kind of what I thought. What bolt pattern are you referring to?
Provide a few more pics from a little further back without the wheel/tire. I bet Mud could figure it out.I guess I won't know for sure until I tear it apart.
