I bought my 1989 HJ61 (12H-T/H55F) about a year ago thinking it would have 3.73 or 4.11 gearing. I get on trails occasionally, but mainly I'm driving to backcountry camping destinations. So I want highway cruising to be reasonable on fuel mileage and engine wear. I noticed right away it revs higher than my US FJ60 (which has 3.73 gears), so I assumed I had 4.11 gearing. It wasn't until being frustrated with the revs and slow speed on a recent 500 mile road trip that I decided to try and figure out what gearing I actually have. I'm running 265/75R16 BFG ATKO > according to manufacturer they have 31.6" diameter. In 4th gear trying to keep the tach in at 2000rpm I'm going about 41mph according to GPS. Please check my math...
41 mph > (41 * 5280)/60 = 3608 ft/min
31.6" dia tires > Tire circumference = (31.6 * 3.14)/12 = 8.27 ft.
Tire revs = 3608/8.27 = 436.35 rpm
Gear Ratio = engine-rpm / tire-rpm > 2000 / 436.35 = 4.58
Conclusion: I have 4.56 gears.
1. Please let me know if you agree or disagree with my assessment. There is certainly room for error in my method: tire diameter compression under vehicle weight, accuracy of reading tach, bad math, other factors? If I have 4.56 gears, does that mean a PO swapped them? I'm not aware 4.56 was ever stock in a 60 series. The HJ61 was imported from Japan in December 2014.
2. Should I re-gear and to what ratio (3.73)? How do I go about it. It might be worth mentioning that it is a right-hand-drive, so finding a swap could be difficult (I actually don't know how different RHD axles are). I'm in Tennessee.
