"Hell For Stout" or "Man-a-Fre"?
Hello all I am a new member to Ih8mud.com. I am wanting to get your oponions on the "Hell For Stout" and "Man-a-Fre" lift kits. I have an 1976 Fj40 and I want to lift it 4 plus inches. I am looking for a kit that will offer great flex and aslo great stability without compromising durability. The FJ40 is not a daily driver. I use it to go wheeling with "Ragman" and I need to keep up with him. :) What do you guys think? RS
no need to search my friend, save yourself the headache, SOA
Ragman has a way of finding trouble!! My first thought was to do SOA. What do you all think the estimated cost would be to do a SOA. I know I have to, cut and turn the axles, redo my steering, get mini truck drive shafts and knuckles. Should I use the springs that are on the cruiser? They are the original ones. I will need new shocks....etc...etc...doesn't sound so easy.
SOA easy if you know how to weld and fab a little bit.
SUA suspension is pretty much bolt on.
Between your two choices i would go with the HFS kit.
you will need shocks regardless, but it is not that expensive if you can do some things yourself. i didnt need mini truck driveshafts, probably should have done the mini truck knuckes but didnt. would recommend cut and turn, use the springs you got.
hey - i just work here......
Ronnie is a great guy. A total cruiserhead in development.....
For ease of application - both from an installation point of view and cost/time analysis.
I recommended to him:
4" lift + 1" or 2" lifted shackles over stock with a u-bolt flip kit.
This would provide a quick, easy to install solution. Run with that on 35's and enjoy cruiser version 1.0.
If, after a few seasons of wheeling you want more, go for it......
In the middle of a SOA,
ragman (less trouble than pablo)
i say forget about doing it later which he eventually will and get it on
even though I am doing a SOA currently. It is not the only choice cam. It depends on what you want to do with the rig.
It is not as easy as just "doing it". The list is long, much longer than SUA.
You start one thing, and open a new can of worms. Now, granted when done - sure - it is a sweet setup. But there are drawbacks and cons.
Before just "doing" things, it may be (in Ronnie's situation) a good idea to jot down the pros and cons to each scenario, then go from there.
ragman
didnt say it was the only choice dox, you wanna do an easy lift and you got no time go sua. dont worry i have done my share a research and reviews and was going to do the hell ...... sua, but now that i am finished, and yes it did take longer thann just taking out the old and putting on the new, i am very happy that i went soa rather than sua. and if he is to "keep up" with you dox as he states, then soa is in his best interest.
WOW! sounds like things are heating up!! I think that I am going to go SOA and have "Ragman" put it on for me!! I dont want to do things twice. If I will be happier in the long run with SOA than that is what I will do, however if I can be as happy with SUA than I would rather do that. If I was going to do a u bolt flip kit I might as well do a SOA because a flip kit adds $300 to the SUA lift kit price. "Ragman" warm up the welder...ill be over in a minute..
