HEI problem
It just stops or misses realy badly before it dies.
I got it to do it in my garage. In neutral, I reved up the motor with timing light and vacuum gauge attached.
At idle, gauge read 20psi.
At initial throttle, gauge read dipped to 5psi
At steady throttle, gauge read 19psi.
At off throttle, gauge read 25psi, then back to 20 psi at idle.
When it was at very high rpms, the light started flashing sporatically or not a tall and the vacuum dropped to about 10psi. If I let off the gas, it comes back to life.
I have had fuel delivery problems before. I know what feels like when it "bucks" due to lack of fuel. This is not the same thing and there is plenty of fuel in the carb.
My 78 did the same thing NEW from the factory. Start, drive for a couple of minutes and it would loadup and stall. Crank it over for a long time and it would start up with black smoke out the exhaust, indicating excessive fuel. It would run fine until I stopped and let it cool down, then it would do the same thing again. It was in three different dealers shops for two months and they couldn't find what caused the problem, even when it happened to the mechanics when they would put the cruiser on the road. It had to be something in the emission system since my solution to the problem was yank the 2f with less than 2000 miles, put in a presmog chev v8 and sell the 2f. The 2f was put in an older, pre 70, cruiser stripped of all the smog and ran like a champ. I know this doesn't help you, but a vortec my be in your future.
your kiddin right? new from the dealer in 78? didn't run right and you yanked the motor and stuck a SBC in..............
Could too much advance be causing this? I pulled the vacuum advance from the distributor and it is not happening anymore. Revs up without missing and does not stall. I dont like the decreased performance.
I'll continue to drive without vacuum advance and see what happens.
I replace my intake manifold and gasket a while ago. I just got done retightening the bolts. The seemed pretty tight already so I dont think this was the problem. I also set the gap to .040.
Some of the plugs looked "hot" which could mean too much advance. They are NGK plugs which I have been running for a long time now.
The motor has good compression (125 all around) and I have replaced so many parts (fuel pump and fuel lines, water pump, distributor, rebuilt carb, oil pan gasket, all radiator hoses, ect...). I really dont have the desire or money to put a V8 in it just because I cannot work out a few kinks. I also like the fact that I have the stock motor and would be a little ashamed to say I put a V8 in my cruiser.
Some day I might go with a V8, but not yet...
"your kiddin right? new from the dealer in 78? didn't run right and you yanked the motor and stuck a SBC in.............."
Nope, not kiddin! After my wife and daughter were almost killed in an accident because of the stalling problem. A driver of a cement truck wrecked his truck to avoid hitting the cruiser when it stalled out in front of him. Toyota had no idea how to fix the problem, and this was before the "lemon" law, so I was stuck with a basicly unusable vehicle. I have been happy with the sbc. Built the first one myself and ran 165,000 miles before replacing with sbc II, Custom built with 55,000 and runs great. In Calif. smog equipment was the issue. Small block did not require smog in 78. Thought it was my best choice then and still do now.
When it was at very high rpms, the light started flashing sporatically or not at all and the vacuum dropped to about 10psi. If I let off the gas, it comes back to life.
So you're saying the timing light starts to disappear when the engine loses power? :confused:
Does that not indicate that spark is too weak (or nonexistent) to trigger the light? :idea:
just a thought but you said your total advance was 40. usually total is the reference to the initial (dui recommends 12) plus centrifical -about 24 i believe.
vac is only gravy for hiway/fuel eco driving. really dont see 4 degrees making that much diff. but never can tell.
jim
did you ever solve your prpblem? we seem to be having similar probs withthe HEI.. no spark at all, and it all started with a bad missat higer revs and would not idle. now nothing.
thx jim
thx jim
replace cap/coil
hey just to make sure, you don't have your ballast resistor still feeding the HEI do you? I know on all my cars that I have converted I had to toss the ballast resistor so it would get the full twelve volts.
will check to see if is spinning in the a.m. the way it was acting before it died, it seemed fuel related, now this. i am thinking week coil that finally died. the module is normally either good or bad, correct//////////////////////////////////////////////////?
no inbetween. has been working goog for about 9 months now this.
thx jim
If the engine starts firing again after you pull the choke out, it is a sign you are not getting fuel. Since you said there was fuel in carb, my guess is there is dirt in the main jet or fuel bowl and it's periodically restricting your fuel flow. Just my 2 cents.
hei
thx for asking. called maf and sent to performance. nice guy originally from round rock (near here), larry i think, sent first a module which did not solve the problem but did help as the old was bad. (lots of swapping) then sent a coil which did sem to solve it all.
all of this at no charge. really need to keep spares on hand. no idea why or what happened. now have a new problem-feels as though during all this blew a power valve or something in the carb--38 weber.:frown: :beer: :beer:
jim
Hello Jim
Hey Dude,
It's Richard from Southlake, TX (Jeff's buddy)
How's life treatin you?
I was checking IH8MUD, because my 69 J40 is doing the same thing
that your FJ40 was doing when you, Jeff and I was working on yours
at Jeff's shop. I don't have the HEI system, but all of the ignition system
has less that 200 miles on it. On Friday I plan to start by replacing the
coil. One thing about my issue is that it's intermittent, but when it starts
to act up it idles fine and between 1500 and 2200 RPMs it sounds and
feels like it's missing on all 6 cylinders.
Happy Thanksgiving!
Later,
Richard
:beer: :beer: :beer: :beer: :beer: :beer:
I really think we have problems with this HEI stuff. any one think same?
