Headlamp Washer Tanks Are Here- Giveaway
don't be surprised if your valves (85031) are leaking. The last time I worked on my headlight washers all the fluid in the reservoir leaked out from the valves. Partsouq shows them available. I just ordered. We'll see. Lately I order parts that online parts stores show available ...only for them to void the order later because NLA or not in stock.
Just ordered mine… anyone know where I can get a new one of these hoses that is next to the bottle and also damaged in my picture? Also a headlight washer pump.
I may have another pump laying around. I'll take look in the shed in a few days when the weather warms up.
Found a spare pump just need to test it. PM me if you are interested.
I had this issue a few years ago, after hours of searching I did find a valve but I removed the tank for a dual battery setup...
edit: theyre on ebay PN 8503130020
I received my tank and got around to installing it in the Fj60 today. It was a perfect fit and went into place without any drama. I’m so glad I got the grommet to the pump as mine disintegrated when I removed the pump from my old tank.
Pro tip: If you’ve never had a working pump, you may not know that the headlamp washer is activated with the windshield washer button but only when the headlamps are on. I went on an unnecessary troubleshooting exercise because I didn’t know. On the positive side, I now know where the washer relay sits, behind the driver side kick panel, below the fuse panel 😊
Pro tip: If you’ve never had a working pump, you may not know that the headlamp washer is activated with the windshield washer button but only when the headlamps are on. I went on an unnecessary troubleshooting exercise because I didn’t know. On the positive side, I now know where the washer relay sits, behind the driver side kick panel, below the fuse panel 😊View attachment 2917033
please post lots of the @TRFarmers Tank Installed in your truck like you mention above ?
come on man we all got to see it and see it right Fracking NOW ! .............:D
i could be wrong here ?
has ANYONE installed these Unicorns and posted any Photos yet ?
if NOT BRING Them ON ............
who cares about the relay location ? :rolleyes:
:flipoff2: Hi to you too @ToyotaMatt
It got too dark to take a pic of the installed tank but here’s the tank with pump installed.
Great info! Especially about the relay...
