Headers
Who's running headers from advanced adapters. I purchased a pair and had them ceramic coated. Now that I have the body on, the headers sit real close to the firewall.
Seems from the position that they'll get real hot and cause my feet to burn.
Suggestions, expereinces?
Here is a sample of what NOT to do.........
The PO had to cut the fender wells to accomodate the exhaust, as you can see. The output does hug close to the firewall, but does not seem to affect the temperature. Not sure if these were from AA.
Those headers look very, very similar. I don't think I'll have to cut the fenders. Actually, I won't cut the fenders. I hope I didn't waste more money... I lined up the headers to the fenders and it's tight as Hiliary Clinton on her wetest day.
Send them back
Send them back and get some exhaust manifolds. It ain't a race car. Do a search for ram horn or rams horn exhaust manifolds.
Headers are too much trouble, and those go under the frame rails.
JR
I am running those, floor board gets warm not too hot, my engine sits a good ways up.
You could always wrap them with Thermo-Tec Header wrap from summit racing.
JR
Uno, seriously do the above! you will be much happier with rams horns exhaust manifolds. I have headers and they have been trouble, including the coating. I wish I had gone with some simple rams horn, much cleaner end design.
Noah
Guppie, I do believe I will take the same advice...even though the fenders are already cut. What I did not mention was the placement of the exhaust relative to the headers: the exhaust runs underneath each door, exiting at the front of the rear tires.:doh:
Sounds nice, but not worth hanging on a rock when it finds one really easily.;p
yeah right,
you can cook a burger on the fire wall with these things, get yourself some ramshorns
I would like to get the rams horns, but I already ceramic coated (interior & exterior) the frame over headers from advanced adapters. I have too much money into the headers to just throw them away (AA won't take'em back). The headers fit becasue we have the motor so far forward, but they are close to the firewall near the floor board.
Suggestions....
sell them or run them, you can wrap them in heat wrap as well. youll be fine, just keep things that can melt away from them
Been there. Hang them on the wall or sell them because even if you install them you will have to live with them until they rot out and that shouldn't take but a couple years. Plus every wire under your hood will be well-done and carry a combination wrench with you so you can tighten the header bolts daily. You could not give me those things.
I am sorry you are into these things so deep. My advice would be to cut your losses. The only long term solution I have found:
