So I did the HG on my '94 last spring, and it blew again this week. I haven't checked cylinder 5 compression yet but cylinder 6 is at 30psi and the plug is covered in black soot- it's a dead hole. The first time around my machine shop sold me a shim- basically a precision cut piece of sheet metal- that got sprayed with copper HG sealant and went between the head and gasket. This was because they shaved 15 thousandths off my head due to pitting. The shim was .020 thick to make up for this. I also used a cheap gasket (idiot). I never had the block decked and I'm not sure I want to this time either because of the cost. I realize there's a lesson in here to be learned.
I'm wondering now what guys know about Cometic head gaskets,( @scottryana I've read some of your comments about them, maybe you could chime in?). Maybe I should look into a .015 Cometic and forget the shim? It seems to me maybe it would seal better than the shim/ gasket combo. I've never priced one, maybe it's cheaper to deck the block and run Toyota parts this time and forget the shim/spacing. Short of going all out on this engine, what can I do differently this time? Can I skip the shim and use a Toyota gasket?
