I’ve seen several/numerous/many pics of builds/mods where the two bolts that hold the air cleaner assembly on the head are removed so the assembly can, well, be removed
. So if that was the case with my F135 motor, purely hypothetical of course
, what’s the process to reinstall these bolts? Do you go through the normal FSM torque sequence through all the bolts until the max torque has been applied to every bolt, or just torque those two back down?
And, in this hypothetical scenario
, what if some issues like some oil burning or milkshake in the fill tube showed up (haven’t checked under the valve cover yet, hypothetically), do you think the bolt removal might be a contributing factor, and retourqing might help, hypothetically of course?
If it might help, hypothetically, is the only way to torque the #1 bolt under the rocker arm assembly to remove the assembly, or is there a torque wrench made for that situation (metric crow foot)? Hypothetically
