Having EZ Locker issues.... Help Please...
Spokane, WA
I put an EZ Locker in the back of my '70 40 a few months ago. The spider gears were originally welded so I just got a whole new third from one person and a couple of thrust washers form another guy. At the time of install the gap between 'looked' acceptable. I had no way of verifyng exactly what the clearance should be.
I later found out from Woody:
"IIRC, .152 is ideal.... .140-.170 is the range...mine is .150..."
The symptoms are that I seem to be getting an excessive amount of the loud "what the hell just happened" pops when turning corners and when maneuvering in parking lots. Sometimes it will work just fine with no noticable clicks at all. When climbing they seem to lock up perfeclty.
When the loud pops and bucking start when turning a 90 degree corner I'll try pushing the clutch in to remove back pressure but it still does it. I'll even try gaining some speed then pushing in the clutch and coasting around the corner, so there is no positive or negative pressure, and it still pops and bucks 85% of the time.
When cruising at 40-50mph around a gentle corner while keeping moderate acceleration, the back will pop loose causing oversteer, then re-engage, then pop loose over and over. There isn't a gentle clicking through the turn like I expected.
So my question is does this sound like maybe its too loose or too tight? Or did I get a lemon? (BTW - I've matched the tire pressure already.) I'm trying to figure out what new washers to order, get the thicker ones or the thiner ones...
How do I measure it when apart? Just use a feeler between the two halves that the pin goes through?
Pull the rear cover and measure the gap between the two halves. If you're like me and don't have any feeler gauges, use a couple of drill bits as go/no-go guages. 9/64 is .140 and 11/64 is .171.
Basically the 9/64 should fit and the 11/64 shouldn't.
phishtaco said:
sounds like just normal locker characteristics to me
Really? I thought that most people say that their's are pretty transparent when in a parking lot. I hear people say that they get one loud BANG right after they install, mine just keeps on banging.... Its embarassing loud :D
Low speed tight turn manuvers like in a parking lot will cause my lockrite to buck and click and clang like crazy. Totally normal. You learn to coast into parking spots and all you get will be the clicky sound.
I would still pull the cover and verify your gap. I think most lunchbox locker failures are because of an out of spec gap.
how was the case surface on the carrier ?
new thrust washers may have been to small , I did my 70 fj40 with a lockright and it did what you describe once in a while and I thought cool , normal operation , then first trip to rubithon and by cadillac hill the thing was poppin every 10 ft. I would say your gap is .0625 to large .
causesa the teeth to wear the corners fast instead of working on the ramped area of tooth....
Parking lot is where you will hear it the most ie..tight turns. Push in the clutch and coast has always seemed to help me. This was in my Tacoma, little bit longer wheelbase, should be worse in a 40
Go to a Toyota dealler and ask for the thickest side shims made for the LC thirdmember. Throw them in and then drive it around. I bet you won't be saying, "WTF was that" as much. That is what I did. I do get the occasianal pop but not nearly as often as you describe. Everything is nice and tight.
i got an aussie locker and had the same questions many people have when new to the locker world, it is normal and still drives me nuts when it bucks and pops sometimes its scary but have had no probs so i live with it. when parking i just park far away and avoid the tight turns
The bucking and kicking in parking lots are what will eventually drive me to ARB lockers. The clutch makes mine worse if anything. maybe it's time to recheck the gap for me too.
troy
This ain't right.
Lockers work the best (smooth and quiet) while keeping a steady, constant pressure on the ring gear, either acceleration or deceleration. The fact that your is popping and banging even under the optimum conditions suggest that either it isn't set up properly or the axle housing may be bent, which really plays hell with them.
Pin_Head said:
This ain't right.
Thanks, that's kind of what I thought. With even pressure on the gas pedal I figured it shouldn't be coming lose like it has been.
Everyone else, thanks for all the advice. I think the best thing to do is just pop the cover and re-check the gap just to put my mind at ease. I have a big wheeling trip coming up in 2.5 weeks and hope I can get the washers in time. Sounds like ordering the thickest ones would be a safe bet to start with?
I didn't notice unusual wear, but I wasn't looking that closely when I did the swap. I'm thinking I'll just order the thickest and go from there.
Thanks!
