Handheld Techstream Alternative Found!
I just programmed a new key FOB / transmitter for my 2013 LX using the launch.
Get to this screen. Some users reported getting into an endless loop of only OBD2 scanner function and not being able to change settings. If you select Auto Detect or let it do it's thing this will happen.
I selected Lexus (do not select AutoDetect)
16PIN (North America)
My truck does not have radar cruise so I selected Others (not sure it matters though)
It correctly scanned my VIN and identified my vehicle
OK
Service Function
Immobilizer/Keys Programming
Smart Code Registration (Classic)
OK
OK
OK
I am just registering keys
Touch existing key to ignition. You will hear a double beep.
Touch new key to ignition. You will hear one beep, then another one or two beeps shortly after.
I let this time out since I didn't have any more keys
OK
old key on left, new key on right
old key on left, new key on right. Note different FCC ID.
HYQ14AAB vs HYQ14AEM
I bought the FOB / transmitter (89904-60A00) at my local Toyota dealer (yes they sold a Lexus part) for ~$125 (15% off sale). I bought the metal key (69515-50260) at my local Lexus dealer and had it cut using my VIN for ~$63 (included both key and having it cut). So under $200 all in.
OK
Thanks for posting. I have a brand new key waiting to try this.
Ok thanks to @sdnative instructions and @Boston Mangler with the heavy lifting I successfully coded my new key. Did not need a PIN code. The menu was in different spot but we found it. For reference my truck is a 1/19 build date. I am at the local Penske Toyota dealer and they are cutting the key shank for $60. Rather productive morning thanks all!
Correction: the key is already cut! Looks like the cpo dealer I bought the truck from already had the key cut according to the vin. Free 99 thank you very much
Glad we finally knocked this out man! 👍🏼
Anyone know why it looks like this is unavailable on Amazon? Permanent or temporary? Share a good link if you have one!
Thanks @gaijin ! Ordered and excited to start playing. I don't suppose anyone has found if you can adjust the speedometer/odometer/mpg/etc. for larger tires?
Can you post up where in the menu you found this? I have a 2021 and haven't found it yet. Thanks!
Gosh all I remember is that it wasn’t in the same spot as @sdnative truck and it took me a good 10 minutes of searching before I found it. I think I had to exit and go back to the main screen and clicked one of the other options. From there I found either keyless entry or smart key and the rest of the steps wire identical.
Between this one and the OBDLink MX (140$), what do y'all recommend?
I just got the Launch Creader Elite 2.0 for my 2011 LX570.
I bought it to force the A/C actuator initialization. Only my driver's A/C vents blow cold air, and it's miserable to drive right now. Anyone been able to do this or successfully? It seemed like I could manually move the servos, but I was never able to get cold air coming out of the other vents. Seems like it connects and does what it should. I changed some settings successfully.
I think the culprit is error B1449 Air Outlet Damper Control Servo Motor Circuit (Rear). I'd like to be able to flash reprogram the A/C amplifier module, but I couldn't figure out if the Launch.
Any ideas? Thanks for getting this thread going...very helpful.
Any update on this - were you able to recalibrate servos? I need to do the recalibration after getting a new battery. Have similar issues with the a/c.
Just attempted to find the computer brake bleed procedure in the menus and was totally stumped. Any clues on how to navigate to the right area?
It’s definitely in there, scroll through this thread. Both me and @badsamaritan have used this to bleed them. I’m drawing a blank on what it’s labeled
I was able to recalibrate the servos, but that wasn't the bigger issue. Turns out I had a very slow coolant leak from the coolant valley. I don't have a paved driveway, so I never noticed any fluid drips from my vehicle. Fixing that and adding new coolant fixed the AC issues. I had other PM work done while it was in the shop, but I'd have to look at the invoice to see what all was done.
I also have done a few tweaks to the options (seat belt ding, etc.) and added a new key fob. So, the unit has more than paid for itself.
