Handheld Techstream Alternative Found!
Same for me. I got it to go into vehicle settings a couple times but usually it just goes into the read codes mode and there's no clear or simple way to navigate out of it. Doesn't help that it's pretty damn slow.
I just got the Launch Creader Elite 2.0 for my 2011 LX570.
I bought it to force the A/C actuator initialization. Only my driver's A/C vents blow cold air, and it's miserable to drive right now. Anyone been able to do this or successfully? It seemed like I could manually move the servos, but I was never able to get cold air coming out of the other vents. Seems like it connects and does what it should. I changed some settings successfully.
I think the culprit is error B1449 Air Outlet Damper Control Servo Motor Circuit (Rear). I'd like to be able to flash reprogram the A/C amplifier module, but I couldn't figure out if the Launch.
Any ideas? Thanks for getting this thread going...very helpful.
Ok so bought this and now about to update the software.
Is it me or when the unit sleeps that the download process is paused and you have to reload again?
Weird.
under what menu is the TPMS reset? I think I found it but it’s asking for a transmitter ID code. Please don’t tell me the code is on the TPMS.
I've found I need to navigate to generic OBD2 reader then back to the VIN reader (Toyota/Lexus specific) in order to get it to provide the other menus.
Hi guys, what am I doing wrong?
If I need to reset TPMS sensors, how does this unit detect each sensor code? Is this capability possible?
I took our LX to a tire center to get to acquire the ID codes (TPMS sensors are already installed).
I entered the ID codes for all 5 tires and registration failed.
Ugh. I am this close to throwing this against the wall because the menus absolutely suck.
Jackpot:
I don’t know if the solution was inputting all 5 sensors correctly (my spare TPMS sensor was already registered and working properly but for giggles I decided to enter it again).
Anyway I inputted all 5 correctly under main tire set. I also cleared all DTC codes related to the TPMS just in case.
If done correctly the TPMS dash light will go from solid light on to blinking. After a few minutes the light will go off.
This saved me at least $100 so it paid for itself.
Also it did reset my HVAC and now have drivers side vent working again.
I still think the menu system stinks though.
Yes, agreed. Does anyone have a working procedure to always access the customization or diagnostic menu? Sometimes it just loops in the scanning mode forever. Don't even know what I pressed to get out of the loop sometimes.
It always scans in my experience.
Here is what I do:
1. Tool scans vin automatically. Don't hit ok
2. Hit home button
3. Hit diagnosis
4. Hit Lexus or Toyota. Software version screen pops up. The hit ok
5. Manual select
6, 16 PIN DLC North America
7. ModelYear
8. Radar Cruise (I have radar cruise so I pick this for my LX)
9. Hit ok
10. System then scans the car
11. Then select “system selection” or “customize setting” to fiddle with your settings
Here is what I do:
2. Hit home button
3. Hit diagnosis
5. Manual select
7. ModelYear
9. Hit ok
I will try this. Thanks
If you have the codes for all 5 TPMS sensors, input them manually one by one. This did work for me. It does take a few minutes. It is not very satisfying. You can program two sets of tires. (I have a 2015 LC).
Bought the diagnos tool thanks to this thread and very happy with it! Thanks to all of you who have put in the valuable info.
Now a question. i suspect that one of my height sensor on my AHC system is out of calibration after AHC repair. the front left corner is 5cm (2inches) to low.
I found the height sensor calibration/adjust menu abd it wants me to fill in a height. however it does not tell me which height.
I have searched on the forum and found 3 different height that are refered to. (ground to wheel arch, center of wheel to wheel arch and ground to suspesnion arm)
Anybody done this procedure and can guide me in the correct direction?
Search for "height offset utility" thread and start there. I don't remember exactly how I did it, and it took three tries IIRC, but I was able to fix the same problem with this gizmo.
Thanks - found it. looks promising! i will give it a go later this week.
Thanks for the feedback and info @Romer
Also worth noting, met up with @dudemancool1904 this morning and plugged the unit into his (not sure year, but much newer than mine)
When plugged into his, there were quite a few more options under the “others” menu
I have the button to fold my mirrors in, but was trying to get them to fold in when I lock doors. Option wasn’t available when plugged into mine, but plugged into his, the option was there.
Also, I’m trying to find where to find the PSI threshold the TPMS dash light comes on at to lower it a bit.
Glad to see this is going to be a good option for all once we do more trial and error!
Good stuff!
@dudemancool1904 - what unit do you have?
Do your units also review and manage the AHC system?
