Hey Gang....I am holding a HAMOM on May 5th to finally get my 40 back on the road and trails. All are welcome, I'll have refreshments and some kind of lunch...if we're workin till dinner I'll get some pizzas. This will be a very informantive wrenching day...on the list
Weld in floor board and weld in seat brackets
Lower rear engine and attach e-brake
Complete weld the spring perches
Attach rubber brake lines
Attach front calipers
RDB conversion
Fill all fluids
Adjust the steering arm
Bleed the Brakes
Drive it around the block
I have everything preped and ready for the 5th all that is left to get are the calipers and the rubber brake lines from NAPA. I believe this list is very doable for a group of us to get done in a day. My goal is to have my 40 back on the road by my B-day on the 21st of May and I know we can do it. I will need a welder and I always incourage you to bring your tools cause I know I don't have them all....I do have the tools needed for these jobs but I'm sure someone has a better one than I. If you have a "bolt" bucket please bring it...I plan on buying a bolt kit from the parts store but just in case. May 5th is pretty well set, so unless something comes up personally and I have to change it you can mark it on your calender.
Thanks a bunch guys hope to see you there!
Chuck
RDB conversion
Fill all fluids
Bleed the Brakes
Chuck
