Cruiserdrew
On the way there
why is this critical? and by shift linkage you mean just the shifter and associated rods / retainer on the transfer case?
Noah
It's critical because the shift linkage from 84 and down is too short to shift the 4WD shifter rail, since it's built to use on the shorter tranny. Remember, the 85 up H42 tranny got an extension housing to make it the same length as the H55, so those shifters work.
It's also necessary to make a cross member to hold the tranny, since the 81 and up H42s mount differently. I saw a slick set up that Mudrak did, where he took the cross member out of an 81 FJ40, and used that to support an H55f in a 69 FJ40. It looked factory. You will also need that rear motor mount if you go that route so add $125 to your planning.
And one other thing. If you need the e-brake, then MAF may be your only option. If you don't, the flanges from all years of the split case will interchange. Up untill 84 the flange bolt pattern is correct for 75 and later FJ40s (and possibly earlier-measure). To make mine work, I used 83 flanges to match up to my existing 84 bolt pattern, so I could retain the same driveshaft pattern. The alternative is to swap new flanges on your differentials.
