I'm about to fab up an acrylic plate and a riser to mount the high beam LEDs using the brackets. I hope I can get these things together by next week.
That's what I thought. I'm sticking with HID!That’s my understanding, you’ll have to buy one or potentially two units again. If the fan, LED, chip, fails or whatever, its junk.
That's what I thought. I'm sticking with HID!![]()
Some clear 2.5 lenses that you can buy from TRS fit but they don't focus the light properly and the others that do require a 3d printed shroud to hold the lens snug in it's place. That's what I had to do.I don't think you can use threaded aftermarket projectors with projectors. Or at least not with the stock GX setup. Below is a pick of the stock projectors. The adapter plates replace mount to where the stock setup mounts and allows for adjustment.
Regarding modifying stock projectors. You can swap it out for a clear lens and also modify the cutoff to get rid of the squirrel finder.
Maybe we need to get this guy to release again... maybe needs another batch to be done.Well, I finally worked up the nerve to try this and BxBuilt isn't selling the brackets for the time being.
2002-2009 1st gen Lexus GX470 G5 MD2S Retrofit C-Bracket
Retrofit your 1st Gen Lexus GX470 with a Steel, laser-cut and formed C-Bracket. Fits 2002, 2003, 2004, 2005, 2006, 2007, 2008 and 2009 Lexus GX470 with MD@S or G5 Projectors. (J120) C-Brackets replicate the factory mounting points allowing for a no hassle installation. These Brackets convert the...custom-brackets-designs.myshopify.com
yeah I was going to update with that. I don't know much about the BX built LED projectors, but I have my qualms about LED projectors, while they are 'self contained' if they fail, you may have to replace everything. Whereas the HID systems, while having multiple parts, projector, bulb, and ballast, all are replaceable and somewhat economical. But the projector itself is just a lens with an actuator for the bi-xenon function. IF it fails, all that will happen is you won't have bixenon. If bulb fails, its easy to find replacements as is the ballasts.
forum.ih8mud.com
forum.ih8mud.com
