- Joined
- Feb 13, 2020
- Threads
- 93
- Messages
- 839
- Location
- Chandler, AZ
- Website
- www.wastingtimeinthewoods.com
Great mod. Any concerns with wire gauge / fusing or did you run a new circuit?USB install a success.
Nice!@GrizzlyClint
USB install a success. I edited the original post with an explanation and pics:
Has anyone replaced the dual USB + aux data ports under the front console slider with USBs that actually can charge something? I can't for the life of me figure out why Lexus insisted on installing two of those worthless things up there. Now that I have wireless AA I don't have any use for any of the data ports but even if I did why would I need two?
I pulled the Lexus USB + aux box out, and using some decidedly non-scientific measuring, I believe the internals of the box are just a hair larger than a Carling style switch set sideways. Several reputable manufacturers make dual...
Ran a new circuit to a constant power blank fuse. See link.Great mod. Any concerns with wire gauge / fusing or did you run a new circuit?
Do it yourself. Wintertime is upon us. A few weekends and you'll be as good as new. If you buy a used engine, can I have your old one?Looks like I am a member of the blown headgasket family. Started blowing white smoke at startup last weekend.
Looking for a shop to do the work.
Mostly because of the unrecoversble time and money i have into the truck.
Nice clean install! But...@GrizzlyClint
I have not read that thread and I am unaware of any issues you had, but I don't really mind losing it. I've never had cause to use it, ever, in any car I've ever had. I think I'll be okay...Nice clean install! But...
Just an FYI, I'm glad if still have the 3.5mm jack. If you've read my recent posts on my build thread, you're probably familiar with the problem I'm having with my head unit locking up when either my wife's or my own phones are connected via Bluetooth.
My work-around has been getting a USB-C to 3.5mm jack. Doing that I can still use Spotify on my phone through the ML stereo.
So for me, I don't think I'll be deleting the 3.5mm jack anytime soon.
Absolutely not. I dont even have a space to work on it and have a bad back.Do it yourself. Wintertime is upon us. A few weekends and you'll be as good as new. If you buy a used engine, can I have your old one?
Missed this post.Looks like I am a member of the blown headgasket family. Started blowing white smoke at startup last weekend.
147kMissed this post.How many miles?
I cannot even imagine that at such a low mileage. Are you the second owner?147k
Absolutely not youre not going to attempt it, or absolutely not I can't have the old engine? Are you sure you dont have a valley plate leak into the intake? Have you done a cylinder compression and leak down test?Absolutely not. I dont even have a space to work on it and have a bad back.
In general you should run a wet test immediately after running a dry test in each cylinder, with all tests performed on a warm engine. Toyota does not list that in the FSM but it's more or less "standard" procedure for compression tests.Broke 100,000 miles, and now Cylinder 8 is misfiring in mine. Replaced spark plugs and inspected things with a bore scope to see if there were any noticeable cracks.
Then jumped to the compression test. ~185-190 PSI on all but Cylinder 8. 8 is hitting 130 PSI.
The next test is a wet compression test to see whether we're dealing with rings or a gasket today.
Bummer dude.2nd owner
I have a service connected back injury that would preclude me from doing anything engine swap wise.
Not to mention I dont have a space to do it
I have helped friends do engine swaps and I have no interest in that BS.
Old engine will have to be turned in for core.
Exhaust coming out of radiator.
it's been tough for the 1UR/A760F recently
I went with a CSF to avoid a radiator fiasco, which is also available for the 460 now. Granted, what appeared to be the original OEM Toyota/Denso was still fine at 191K! Can't imagine it would have lasted much longer.Maybe. But I think this is also the only forum that isn’t bloated with ads so maybe we just here about breakdowns more.
Ive got 220k and the only repairs Ive done are a throttle body and valley plate leak (@200k).
Keep in mind @Hiluxforever had a overheating incident from a failed aftermarket radiator.
That reminds me. Time to change the radiator again…
