@GrizzlyClint
wut
wut
All yoursIll take em.
Ignore it. Lol@GrizzlyClint
wut
I need a good shop to do the same to my undercarriage. I also really would like a deep clean underneath.
@Cold Iron digging the garage lights.
I do mine in the driveway. Rig is up on jackstands with the wheels off, and I'm armed with a pressure washer. Woolwax/Fluid Film can be DIY applied pretty easily with a gun that Woolwax sells. It's a messy job, so I only do it every 3 years or so.I need a good shop to do the same to my undercarriage. I also really would like a deep clean underneath.
Which flavor of SL? I'm a proponent of them as well but usually drive pretty conservatively off-road. And there seems to be some variation in SL tire construction/Max psi/etc.Well my years of running SL tires and telling people "I've run SL tires for years without any issues" in forum posts about LT tires may be over. I popped both rears this weekend. Yes I was aired down and yes I was also doing something dumb.
Mickey Thompson Baja Boss 285/70r17.Which flavor of SL? I'm a proponent of them as well but usually drive pretty conservatively off-road. And there seems to be some variation in SL tire construction/Max psi/etc.
If you are going to hoon offroad there is a argument to run MTs. The carcasses are significantly stronger that ATs.Mickey Thompson Baja Boss 285/70r17.
Obviously it's likely I was just unlucky and/or did this to myself via the power of hooning. But I do wonder if the full bumper/armor GX with passengers and stuff is too fat for standard load.
I was considering the Bajas when I got new tires. They are a bit lighter than the AT4Ws I went with (48 vs. 54 pounds) and have a lower psi rating (44 vs. 51 psi). I picked the Falkens due to the psi rating as I tow often, and didn't want to be running the tires at the max PSI rating. So, it appears that the Falkens may be a bit overbuilt as a SL relative to other, thinner SLs (despite having the same weight rating). Tires like the Toyo Open Country are also super light...even lighter than the Baja. Probably best to go with a C-load for those tires.Mickey Thompson Baja Boss 285/70r17.
If you legitimately damaged two tires flying down a trail, then yeah they are under-sized/under strength for your applicationWe had stopped on the trail for a few minutes and wanted to catch up to the rest of our convoy. Thanks to Dobinsons and Perry Parts that task was accomplished much faster and more comfortably than anyone anticipated.
I have an extra "box" / 'front cup holder' assembly if you want it for cutting up or if you mess yours up...I just had to take the decorative cover off of it to replace mine.Has anyone replaced the dual USB + aux data ports under the front console slider with USBs that actually can charge something? I can't for the life of me figure out why Lexus insisted on installing two of those worthless things up there. Now that I have wireless AA I don't have any use for any of the data ports but even if I did why would I need two?
I pulled the Lexus USB + aux box out, and using some decidedly non-scientific measuring, I believe the internals of the box are just a hair larger than a Carling style switch set sideways. Several reputable manufacturers make dual 2.4+ amp USBs that are set into Carling switch size boxes, so I snagged one - a new Blue Sea 1039 for $25 off Ebay - to try this out.
I think if the Lexus box is disassembled, that the Blue Sea will fit inside. The "lid" of the Lexus box, the part that has the emblems for the USB and aux and the holes for each of them, can then be cut away just enough to flange the Blue Sea and allow the Blue Sea to snap into the box and the box to snap back in place.
Wiring would then be to fusebox, leaving the Lexus wiring hanging unplugged under the console.
I will update once I get the parts, if this works.
To hedge my bets I also ordered this cheap piece of sh!t, so if my eyeball measurements of the Carling style box are way off, I can just mod the Lexus lid to fit a 30mm circular knockout, shave the box sides a little, and run this guy. I would like the extra QC ports, and the voltmeter, but I'm perpetually leery of $10 Chinese electronics...
I really should have stopped by your place when I went through Missouri last week.I do mine in the driveway. Rig is up on jackstands with the wheels off, and I'm armed with a pressure washer. Woolwax/Fluid Film can be DIY applied pretty easily with a gun that Woolwax sells. It's a messy job, so I only do it every 3 years or so.
Highly interested in the result here. I'm currently using my third row power for a USB port like that one you posted but it would be nice to have something that looked factory.Has anyone replaced the dual USB + aux data ports under the front console slider with USBs that actually can charge something? I can't for the life of me figure out why Lexus insisted on installing two of those worthless things up there. Now that I have wireless AA I don't have any use for any of the data ports but even if I did why would I need two?
I've been looking for excuses to start a LLC and do side jobs!I really should have stopped by your place when I went through Missouri last week.![]()
