- Thread starter
- #2,881
So I'm just remembering this... blame the lack of sleep... some more possibly related contextSomething may have been unplugged or disconnected for a short time when you worked on the dash. After all these are CANBUS vehicles, so everything is routed through everything else. That's such an unusual set of codes to appear after some major dash work that I'd be surprised if the two events aren't related. If it "fixed itself" and the lights never come back on, I'd not worry about it. If something is truly unplugged or messed up, they'll light up again. I'd keep the code reader in the GX for at least a couple weeks, just in case that happens.
FWIW, I pulled a motor out of my old Subaru over a decade ago. The clip broke on the main harness between the engine and the firewall. Months later, the plug worked itself just a little bit loose - first causing intermittent stalling - which eventually progressed to the Subie dying on the side of the road. I was not as advanced of a DIYer at that time so I struggled to troubleshoot it. After replacing a handful of electronic parts, I threw in the towel and had it towed to the dealer. They quickly diagnosed it and had it running again.
The other day I was coming home in a rainstorm and did a hard stop when someone pulled out in front of me, when I accelerated after the stop the dash had a bunch of lights on-- traction, abs, basically everything that isn't a CEL. I cleared the codes and nothing came back until today when I was going down a big hill, then the ABS/Trac lights came back on after accelerating again
I don't think it's anything CANBUS related because I had the battery disconnected when the dash was apart and unless something rattled itself loose since then it would have given me the warnings sooner. I'll still check everything if the lights come back.
