I am a relatively new GX enthusiast coming from a Power Wagon that had a goose gear rear seat system(that came with the truck when I bought it), and I really liked the quality and usefulness of their product. However, I could just not justify the prices that they charge for wood + rhino liner. I was visiting my dad and we love a good over-engineered project, so I figured I could make a setup that works well for my usage. What I landed on is this modular system, that makes it very easy to switch my whole outfit to roadtrip/camping/overland mode without much fuss. I hope this build inspires you to DIY and save some money + have some fun.
Part 1/2:
Rear seat removal is fairly straight forward, and there are plenty of videos/forum posts on that, so I will skip that whole process as this post will be lengthy as is.
While I had the seats out, I cleaned the floor and laid down some soundproofing. Next step is to make a base for your platform to lay on. I just went with 1x4 that I distributed evenly in order to support the weight. I used double sided tape to secure them in place . It isn't pretty, but it will not ever be visible and works just fine for its purpose.
For the actual platform , I started with a 48" x 48" piece of half inch 4-ply that I got at Lowe's. I cut it down to 43" x 37.5" , which worked just fine for me. The 43" is the width that goes side to side, and leaves a little bit of space on each side. You could go deeper than 37.5" if you wanted it to butt up all the way to the rear seats. I didn't just because when I'm out on a trip I can shove soft bags and stuff back in that gap.
I then rounded the corners and routed them just for obsessive compulsion sake and sanded everything down so there were no splinters. After that, I took some felt-ish fabric that I had bought from Joann Fabrics for ~$8 and cut it to overlap 6-10 inches on all sides (eyeballed it since it would be later trimmed). Then took some 3M fabric adhesive and applied it to the back of the fabric as well as the top of the board. Stretched it out and laid it over the board with the help of my old man. Then took an iron and got it down nice and flat.
I went with fabric instead of rhino lining it because I get easily annoyed with things sliding around, as they would on the Goose Gear platform I previously had in the Ram. Fabric was cheaper and just made more sense for me.
Turned it over and laid it on the sawhorses and began to staple the fabric down nice and neat.
The way I secure the platform down is by using the two existing outer bolt holes that the seats were secured by. There are two central holes as well but I found it unnecessary to use more than just the outer two. These are M10 x 1.25, but I tapped the holes to make them 1.5 just out of convenience to source the right hardware and didn't want to order bolts I couldn't find at my local hardware stores. (M10 x 1.25 had a fraction of the selection that M10 x 1.5 had). If I ever needed to reinstall rear seats I'd just use a different bolt than OEM, so it is really zero problem for me.
The bolt I went with was a flat top counter sink M10x1.5 50mm, uses a 4mm allen key. There is another set of bolts that are the same but 70mm that I will address later in the next post in regards to the modular aspect.
To measure where I needed to drill the two holes, I screwed in the bolts all the way, and covered the head with red crayon/oil pencil, and laid the board down how I wanted it . Gave it a few slaps over where the bolts were and pulled it up to find perfectly (good enuf
) marked bolt locations. Then I drilled pilot holes and then countersink holes so it sat nice and flush.Then to finish it off and make it nice and clean, I took a metal door threshold and cut it down to fit the board. Worked absolutely perfect and tucks right into the rubber door seal. I would attach this before you take the measurements to drill the two big bolt holes. It was an afterthought so I just flipped the board around and drilled two more holes and now it is perfect. To plug the two previous holes, I just got shorter versions of the same bolt and secured it with a nut on the back just for aesthetic purposes.
(this picture is without the side trim pieces in, but they will normally be in just like the first picture in the post)
That concludes the construction of the default/base platform that I will have in there for the 90% of the time I am using it as a normal cargo /dog area and not on a trip.
The following post will address the modular aspect, as you can maybe assume from the first two pics at the top.
