Grease clarifications please
Albany, NY
I am trying to understand grease usages:
For the birfs I bought the Valvoline Synthetic fortified with Moly (color gray).
I bought it in a tab format, not cartridge.
My understanding is that I am going to use it for repacking the birfs (on the inside) and the cavity that the birfs goes into.
I also bought the Mobile-1 synthetic, the red one. This I bought in a cartridge format. My understanding is that I will use that for bearings.
Since I am down under already, I am going to grease any zerk I can find, u-joints shaft, etc'
What grease should I use for that?
If Mobile-1 red, then I already have it in a cartridge format. This grease does not have moly.
If I need moly, I will have to buy the Valvoline in a cartridge format since it comes with moly.
TIA
Rami
Moly additive is so slippery roller bearings can stop turning and slide, which creates flat spots and the damage accellerates from there. Moly is great for sliding surfaces, like the sliding balls in a birf or the telescoping driveshaft. Moly is not recommended for roller bearings, like wheel bearings and U-joints. A lot of guys use moly in their roller bearings without problems, I have, but that's where the recommendation comes from.
Use the mobil-1 for u-joints. There are 3 zirk fittings on each drive shaft.
Unless someone sounds an alarm, I am going to use Mobile-1 red for everything but birfs.
For birfs I am going to use the Valvoline Syn with Moly.
Thanks for all who responded.
I usually use Mobil1 syn grease for the wheel bearings and chassis lube points...
If you are changing the trunion bearings then I would use the Valvoline moly for those. They are slow speed bearings and are in direct contact, more or less, with the birfs. Otherwise, I think you are on the right track.
