- Thread starter
- #21
Squash,
Couple thoughts on your 1/2 hr service. First, if the seals are leaking it is normally due to the INNER axle seal leaking thin gear oil into the birf, and this seal is only designed to hold in thicker grease from the birfield area. So, I am saying this should only be done by someone knowledgable enough to know the difference by simple visual inspection, which takes experience.
Secondly, I'd suggest not lining up the cuts - perhaps putting the rubber cut at 11 o'Clock and the felt cut at 1 o'Clock and neither in line with the metal part's joint. This would reduce leak/dirt intrusion potential.
Also, regarding getting fresh grease into the birfield itself, it's worth noting that it has been established that fresh grease put in the knuckle via the square plug per Toyota works its way into the entire birf in short order. It was done by adding brightly colored grease just before a teardown. Myself and one other person did it. I still like the greasable birf, but just another data point.
DougM
Doug,
All good stuff; I really like the colored grease idea.
How many miles did you drive it before the tear down,
and how much did it spread?? ie: like striped toothpaste, completely spread everywhere within 10 miles? Photos would have been neat; got em?
G
