Greasable Birfs
cheap and easy
Just doing some brain storming at work and thought of this:
If grease through the square plug into the knuckle greases the birf, then why not just drill and tap the square plug for a zerk. that would be easy. and cheap
I've considered the same. The catch is that you do not want too much pressure in there, which you might get if you overfilled it. Major bummer to blow seals.
Correct me if Im wrong Mike but I thought Pat told me that new predrilled birfs were in the 170$ range.. Im gonna call him later and ask to find out for sure.
I really like the pressure relief valve idea in place of the stock plug. Im always guessing when I add grease, just put in 15 pumps/side the other day actually. You know if MP has something similar for the mine trucks?
On another note, I may be replacing those wiper seals in the near future. I get a decent amount of grease buildup over time, not birf soup mind you, and Im thinking the new seals would keep things cleaner. You can bet Ill be giving you a call when I do it lol.
D
