Good alternator, no charging
Canby Oregon
Ok I have tested for a draw, and pulled the alternator out for the 4th time, changed the Voltage regulator, checked brushes cleaned commutator, and I am not getting a charge, I bench tested the alternator, tested it on the vehicle and there was an issue for the Voltage regulator, so why no charge could it be fuseable link ?? bad battery ( it is a new one), I don't like having to charge my battery at night to drive in the morning
Says you have a 6BT Diesel so I'm confused? Did you retain fusible link at battery?
Had battery checked since you have ruled out the alternator making a charge.
What happens when you run truck and disconnect the battery?
I would say fusable link somewhere or in most cases bad cables. Even though they look good they can sometimes be corroded on the inside. I'm not familiar with diesel models but charging systems are relatively the same. There are different ways to test cables to make sure.
To diagnose you need to measure the voltage on the terminals of the battery with your engine running. It must be 13.6 or greater up to about 14.4 If the volts aren't there your charge isn't reaching the battery, trace the wire down towards the alternator until you find the voltage. If the volts are there, your battery isn't holding the charge and needs to be replaced.
We need to know how you wired your alt for swap. For me I use external voltage regulator which has problems in itself. Mine charges at a constant 14.4 even at idle.
I believe @Dirty Koala took the guts from the stock 80 alt and put them in the Dodge unit to keep his wiring intact. They are both Densos.
Have you checked the ground on the block?
I don't know about the land cruiser specifically, but some vehicles use an external diode in the charge wiring circuit. If you went from using an alternator that used that type of circuit then you'll have charging issues if your alternator isn't set up the same way. Meaning, maybe the Cummins used an external diode in the charging system and the cruiser doesn't or vice Versa. If the Cummins alternator is a denso as previously
Mentioned, swapping internals would be what I'd do to correct the issue. Then again, you'd have to dig into charge wiring diagram to know for sure.
Dodge used the PCM to control voltage. Most go to external when failure happens.
Here is more info, I used the voltage regulator from the Land cruiser, just transferred the land cruiser parts onto the denso alternator from the dodge truck, all of my cables, grounds are brand new, the first few weeks of driving I had no problems, I am getting 13.20 volts either idle or 1200 RPM headlights on not change, I also noticed when I use my blinker the needle on the dash bounces
How is your belt tension? It could be loosening up over time and not spinning alt enough. You can Also check direct charge from alt when it's mounted to vehicle when running.
New shredded V-belt ( I think taking it off and putting it back on I must have damaged it:bang: ), new tensioner , I am just going to get anew alternator, and voltage regulator, I can hear mine screaming, has a bad bearing
When talking with a few alternator places when I was looking for regulators they mentioned that one reason for an external regulator was the high volt alternators get to hot for internal. Maybe that is what failed if you put the Toyota internal regulator in it.
Did you start with a new denso alternator for the cummins and swap in the Toyota internal regulator...or did you start with a used alternator on the Cummins?
I used a brand new denso alternator and swapped in the Toyota regulator...and made sure I cut out enough of the back plate to allow the heat sink on the Toyota regulator to get adequate air flow. How did you modify the back plate?
I took the alternator off the Cummins, and my land Cruiser, took the regulator off, and put it on the Cummins, I cut out the heat sink area to let air flow, it charged great for about 3 weeks, so today I put a new/reman alternator on, and still lack of charge, I ordered a new Voltage regulator, and I should get it, next week,
I carry a spare regulator now. One time it failed I boiled both my batteries. Good thing is my truck is all mechanical post swap so no issues starting or running. Second time it just quit charging.
