- Thread starter
- #21
What kind did you get?
I went to a supply house that carries them, I am not sure, I know the Toyota one is $188.00, this one cost me $25
Do you have another battery to swap in for testing? Have you taken the alternator to have it test?
It sound like your going to have to isolate voltage loss. If it were me I'd start at batt to make sure it holds charges. Then mount alt to truck and test direct output at alt with your truck running. Then test continuity from connnector at alt to battery Or were ever next link would be. There are two ways to test continuity. Check for a short between both ends of the lead, then check for any resistance in wiring. 4 major components are battery, belt, alt, wiring. Even if battery is bad altshould still charge truck enough to run when started.
At least you know the alt is good. Bad cable from alt to battery?Ok I am still fighting this crap, I tested voltage directly off the, alternator 14.4, now to the battery 12.83, I have put everything new as far as charging, Alt VR, brushes, so what am I missing
I believe mine is setup battery negative to external regulator and then alternator ground wire goes to regulator.
I won't be home for a few days but let me see what I can find. I did see the setup but I not a fan of the big long solid piping. I'm sure it is for a purpose but I like keeping things simple. Probably why I have been rocking windows down for yearsCan you post a picture, of your set up, BTW did you notice my AC set up
