GM Saginaw PS Question
Camp Verde, AZ
I purchased the MAF complete P/S kit. I'd like to eliminate the need for the spud shaft and have the Borgeson shaft mate directly to the gearbox. However, although the splines on the spud shaft easily fit over the splined male shaft on the gearbox, and the male end of the spud shaft easily goes into the female u-joint on the Borgeson shaft, the splined male end of the gearbox will most definitely not fit into the female u-joint on the Borgeson shaft. Is something wrong here? I don't see how I can eliminate the spud shaft.
They are likely two different sizes...3/4" 30 spline and 13/16" 36 spline...
Look for a flaming river shaft, or another slip shaft....
I think Downey offers one of these also...
Good luck!
-Steve
Strange, MAF said you could run their kit with or without the spud shaft. I need to call them about that...
On a related topic, I'm doing a Proffitt's SOA and will be flipping my stock fj40 front spring packs, which will move the axle forward 3.5" or so. I also was going to recess the gearbox far into the crossmember to eliminate the spud shaft. I'm wondering...will this put my PS gearbox too far aft to tie into the steering. The axle has Marlin hysteer.
If you recess your steering box further than standard, you will basically have to cut out your crossmember top and bottom, top to clear the hoses, bottom to clear the body of the box. Compromising the integrity of your frame to eliminate a spud shaft is not an acceptable solution. If you really don't want a spud shaft, just buy another steering shaft. Maybe MAF will work something out with you; it never hurts to ask.
Ditto.
Mark...
i used a 3 inch hole saw and cut a hole all the way trough the cross member and mouted the box so the hose outlets are up against the cross member it has worked great so far (over 3 years now) and made my own slip shaft using one out of a chevy and just bought the borgesion joints and a 3ft peice of double d or DD from hot rod shop and welded it all together.
I agree, I'm not keen on cutting into the cross member. However, I reinforced the aft facing side of the crossmember with some 3/16" bar stock, and the bumper also acts as a crossmember. In addition, I've heard of plenty of others here who have cut into the crossmember significantly without problems.
I do appreciate all of the input. It's funny though, the way opinions can be so polarized...I've read posts where people thought that keeping the spud shaft was just about the worst thing you could possibly do in a power steering conversion. I only want to do this thing once, and do it right - it's difficult to determine what 'right' is sometimes though.
I cut my crossmember like a lot of people and it has worked fine for me.
ditto, i ran a 3" tube through it for reinforcement, see my pics for details. theres lots of ways to do it, theres no right way only your way
Why can't you just use a different lower u-joint that fits the gear box? Is the borgeson u-joint permanently attached to the steering shaft?
Hi Theo,
No, it's not. I can do this and I guess that's the easy answer to the first question posed in the thread. Seems MAF should have provided this however, and I am checking with them.
Thanks.
