gettin unstuck?
TJM recommends the winch basket as well due to the fact that their bumper is not made to take severe winch abuse. Yes, you can make the winch work w/o the basket but during severe winch pulls, you will watch the front face of the bumper bow out. I've seen this happen on TJM bumpers :eek:
I've heard of that on the TJM's. I just wish I knew where to source the winch basket.
Thanks Cap.... if you do end up with some more pics of that bumper on your truck from different angles i would be super interested.
Where did you order it from?
I didnt order it. CPJones lives close to me and was going the ARB route so I took the TJM off his hands.
My front mounted winch is mostly for getting other people out of trouble. If I am in trouble it is often not where I need it. It is mostly used for unsticking stuck Jeeps and yanking fences and other stuff around on my property.
I like the idea of the receiver mount. My neighbor is in dirt-work construction. He has a work truck, a play truck and a trailer. His 8K winch is receiver mounted. He can put it on the trailer or on either end of either truck. It works out great. Having a receiver based system not only gives you winch versatility, it also gives you recovery points on both ends of the truck for straps. It also keeps the winch in the garage when not in use so nobody tampers with it.
To connect the winch, you use the jumper cable plugs that are used in the grille of tow trucks.
I got a winch. Main reason is that I often wheel alone. Extra peace of mind there is invaluable. If you always wheel with other trucks, you should easily get by without one.
What about not having anthing to winch to, as in no trees or rocks?
Even though this was a bone head move, there's still nothing to hook to even if I'd had a winch. In this particular case, there was nothing but mud.
Land anchor anyone? What are the options there?
:cool:
front receiver
Go with the medium springs get a reciever hitch installed in the front. Have power run to the front and the back for a winch and get a winch in a cradel that you can store in the garage unless you are going off road. Best of both worlds
Mark
Mark - is this your set up? If so, any pics you can post? Thanks.
:cool:
Get new tires! :D j/k
Not having a thing to winch to is a thing often in my mind. That and the fact that an effective limit of 100' max 110'. Mud isn't fun even with mud tires and yet it too often is a factor on country roads.
Kalawang
FWIW- I was worried about weight as well. I bought the lightest 'beef' I could buy and still feel adaqutely prepared. The shortbus bumper, 12k winch with SYN line ( BIG weight savings here) and hawse fairlead (.5 lb VS 14 lbs for the average roller fairlead) you can cut weight, but it costs you $$.
Do tell... I thought the shortbus bumper only fit a 9-9.5k winch?
Cruiser-poor
I have not done this yet. This is the set up my freind has on his 4Runner and it works great for him. It retained the stock look and he can mount the winch on the front or back depending on which way he needs to go and it also keeps the winch out of the weather when it is not needed. I have seen a couple of pictures on mud of front reciever installs. The one I liked the best was hidden behind the front license plate. I can not find the post so I am not sure who to give the credit to for that idea. This is the way I will go.
Mark
The shortbus bumper only fits a WARN 9-9.5k winch.
My winch is a T-max. Same footprint as the M8000. Lower gears, bigger motor (or so T-max says). I've got a buddy that runs the same winch (on a toyota pick up) and hasn't had any problems yet.
