gettin unstuck?
Im trying to keep my truck as much as a daily driver as possible.... and weighing the options of going with a non-winch bumper to save weight on the rig.
If im always wheeling with another truck, do i really need a winch if i have good tow straps to get a yank out? Is it better to pull a stuck rig out with a winch, or with a strap pulling?
Also, if i go with a non winch bumper (like T17) then i could probably stick with the medium 2.5" lift coils.
Is a strap as good as a winch? No.
Since the cost is the same, what is the problem with the heavy springs?
heavy springs means heavy bumper and winch = heavier truck = worse mileage.
Just trying to figure out if i can get away without a winch.. or if im going to need one. that wayi can get the right springs
Go with the medium springs get a reciever hitch installed in the front. Have power run to the front and the back for a winch and get a winch in a cradel that you can store in the garage unless you are going off road. Best of both worlds
Mark
If you are going to take her off road............I would go with the heavies in the front.......IMHO the front is doing most of the work when you are wheeling around, your engine and trany are stupid heavy and you will put your whole truck on to one of your front corners more often than you think............you will get over the firm speed bumps at the mall.
Depending on what you get stuck in it will always be better to pull slow with a winch...........I have already discovered that when you get your 80 planted in corn snow, resting on its belly, with all 4 wheels spinning......it takes more than your average pickup to jerk you out.......you outweigh all your budies............if I had a winch I would have got out with the first sign of no movement ( never would have got that stuck)........weve all been there, so if your asking get the winch ready bumper, and rewrite your christmas list:D
If your worried about fuel mileage you've got the wrong truck.
im not worried about mileage... i just want to manage the mileage thats all.
does a 9000 winch fit inside the t-17 bumper? T-17 is a little lighter duty the the ARB correct?
I personally have the T17 and yes it is lighter duty than the ARB but its still pretty heavy duty. I wouldnt doubt it for a second with a winch behind it.
I've got a T15 (basically the T17 with hoops, and Hi-Lift points) and it'll handle a 9000 lb winch no prob (Slee's site says you need the winch "basket" to fit a winch, but I don't think that's correct especially since the T17 doesn't need one). The T15 is a bit lighter than an ARB (but still stout) if you want to go the bullbar route.
Lockers get you stuck, winches get you out :D
in other words, if you have lockers and get stuck, it's likely you will have gotten farther (and stuck worse) than with open diffs making recovery more difficult.
Informationally, you can disconnect the spring decision from the bumper decision if it's nonwinch. I recently installed 2 ARBs on my 80s and weighed the difference from factory bumper to ARB non winch. It's in a thread about a year ago but I think it was 61lbs weight gain - inconsequential. People forget that the factory bumper you take off weighs a bit with all its bracketry, etc so it's a NET weight change. The winch model ARB is only a few pounds more, but the winch, cable, 2nd battery WOULD be enough to drive heavier springs.
DougM
capocaccia... any pics of your truck to show off?
I have this one which is at night but right now my truck is at the brake shop getting my brakes re done.
vbpgimage.php
will slees hawse fairlead attach and work on the T-17?
just install a winch behind the oem bumper and be done with it. Someone here just did this and it looks great. You still have an extra 60+ pounds up front but a winch is more useful than a bumper with no winch in it!
The factory recovery points are plenty strong if that helps your decision in any way. Just my opinion.
TJM recommends the winch basket as well due to the fact that their bumper is not made to take severe winch abuse. Yes, you can make the winch work w/o the basket but during severe winch pulls, you will watch the front face of the bumper bow out. I've seen this happen on TJM bumpers :eek:
Thanks Cap.... if you do end up with some more pics of that bumper on your truck from different angles i would be super interested.
Where did you order it from?
If you are worried about weight, you should know that Slee's shortbus bumper is one of the lightest 'winch' bumpers out there. Since slee sells TJM also, you could get an accurate weight difference by calling them personally.
FWIW- I was worried about weight as well. I bought the lightest 'beef' I could buy and still feel adaqutely prepared. The shortbus bumper, 12k winch with SYN line ( BIG weight savings here) and hawse fairlead (.5 lb VS 14 lbs for the average roller fairlead) you can cut weight, but it costs you $$.
