GAWD.....help me decide!
Deep East Texas
O.K. guys help me decide, I have read about suspension stuff until I am blue in the face, and now am thoroughly confused.
Vehicle: 1997 80 series Cruiser, 166,000 miles stock suspension (fairly new OEM shocks) 285 revo’s 35-40 psi.
This is currently my wife’s DD, but we will be moving her into a 100 series in the next year or so (80 then becomes mine).
Here is my dilemma: The wifey is complaining of a harsh ride and wants me to see if I can do anything about it. No doubt… the factory springs are sagging some…but I don’t know if going with something like the kit below will improve the ride or make it worse.
(I am looking at the OME medium 2.5 kit.)
Slee - Toyota 80 Series Land Cruiser - OME Lift Kit details
It seems there are a dozen or more kits (or combinations ) that can be used, hence my confusion)
Here is what I want to achieve (short term):
1.Improve the ride (not so harsh…or at least not any worse).
2.Level vehicle (currently front is slightly lower).
3.Have a spring system that will be reasonably off-road worthy (I have an early bronco I use off-road)
4.Allow for addition of front and rear bumpers later.
What do you guys recommend?
I told my wife that the only way she was going to get the kind of ride she wants… would be to go to a 100 series, but can the overall ride and performance of the 80 be improved with any of the kits available?
Thank you in advance,
Flint.
A stock 80 ride is the least harsh thing you could have. The only thing to improve would be to go to 275/70/16 Michelin LTX's and run 32 psi.
An OME ride will be much stiffer than it is currently. Based on the fact you said bumpers would be added in the future. Once you add the bumpers, it will still be more firm than your stock configuration but much less so than without them.
Might also look into Frankies off Road. From what I have read they seem to be a little softer. NOTE I have no experience with FOR, just what I've read.
Buck
If you're just after a better ride then replacing the current worn out suspension with new oem Toy parts will yield a noticeable improvement. I'd bet your wifes observations are due to worn out factory shocks. When I removed my original shocks at 100k miles they had very little rebound/dampening left in them. The Old Man Emu stuff will yield less body roll but I doubt you'll see any improvement in the way it handles the bumps in the road.
The next thought would be to recommend the stock height replacement springs/shocks from Old Man Emu (OME). Again, the ride won't be cushy but you'll gain a marginal amount of height and more control over body roll.
Next in line would be the 2.5" OME you mentioned. You'll gain a lot in offroad capability but if you don't need it then there's no reason to spend the $ over the stock height replacement.
The shocks I have now are fairly new OEM's from C-Dan (thank you Dan). I put them on about a 1-1/2 yrs. ago.
The Revo's made a noticeable difference in the ride quality (harsher, we both noticed that). Personally, I don't think it rides all that rough (its an 80 series).
So, the consensus seems to be that anything other than stock springs will result in a harsher ride?
If that is the case...she will just have to tough it out until we get her the 100 series
Dan, I like the Revo's too much to go back to the Michelin, actually....I was really disappointed in the Michelin tires it came with. They were quiet, cushy, but horrible in the rain IMO (closed shoulder design).
I think you should just sell it to me and get a 100 series...:)
If not, I have a complete set of Shocks and Springs coming out of my 1997 Lexus LX-450 in about a month. They are in excellent condition. The truck has 110k on it.
Rich
O.K. guys help me add a lift kit and stuff so my wife will let me have it and get her a 100 series.
Here is my dilemma: The wifey is complaining of a harsh ride and wants me to see if I can do anything about it, so I can get a lift, she will complain that it's not improved. I can then tell her a ARB with winch and slee sliders and rear bumper will weigh the suspension down and make it smoother. She still wont like it. Then I'll buy her a 100 series and she will love it and I'll get a nicely built 80!
Flint.
Sounds like a good plan to me
I've had the following:
stock 80 with stock suspension parts new + stock Michelin LTX M/S
stock 80 with stock suspension parts new + stock Michelin LTX M/S + Warn 9000lb winch
stock 80 with stock suspension parts + 275/70/16 BFG A/T KO's + Warn 9000lb winch
80 with 2.5" OME's medium in back and heavy in front + 275/70/16 BFG A/T KO's + ARB + Warn 12000lb winch
80 with 2.5" OME's medium in back and medium in front + stock Michelin LTX M/S + ARB + Warn 12000lb winch
80 with 2.5" OME's medium in back and heavy in front + 275/70/16 BFG MT's + ARB + Warn 12000lb
winch
So, I've had a little of everything. I can tell you that the softest ride you can get will be with the stock suspension. The OME's are a ton better off-road and on washboard, but the stock stuff is far more comfortable on the road.
Just another perspective.
F.O.R. (if you can get it) is really soft even unloaded, although adding lift to soften a suspension is pretty much out of the question. But compared to OME medium, F.O.R. is buttah. Ride stays excellent under weight (I have four kids and gear onboard all the time).
Plus, it was designed for 35's, so once the rig is yours you just need the tires.
The previous owner on my LX had Dunlop grandtreks and the ride was harsh. I went to Michelin LTX 275/70/16's and the ride is much smoother. The Michelins are like pillows (smooth, quiet, excellent snow traction too).
Another thought, 'worn' OEM springs will be even softer than new OEM springs. If the ride is too harsh, she's in the wrong rig. Honestly, getting a 100 probably won't solve your problems either- it's still a truck. Of course she might just want a change of scenery.
-Spike
-Spike
I don't know about that. My younger brother has an '06 and it definitely rides better than the 80.
The 80 doesn't bother me at all, but the wifey has always thought it rode a bit rough.
I told her its just part of the "package".
Drop the tyre pressure down to 30psi. Cheapest option and should buy you some time until you find the right 100-Series.
-B-
