- Thread starter
- #21
progress
So here's what I got done since my last post.
Somewhere along the line the clutch throw out bearing carrier clips (clutch hub clips) got lost. So I could not stab the tranny to the belling housing, clips ordered and will be in thursday.
So I worked on the motor. Got the intake / exhaust mounted to the block last night.
Since I am adding power steering, I had to relocate the AC Compressor to the passenger side. Nostalgic Air offers a FJ40 mounting kit and the proper compressor.
The kit relocates the alternator just below the OEM alternator bracket and uses a plate and adjustment arm, spaces, links and lots of bolts nuts and washers to mount the alternator and compressor.
I also went with a gear reduction starter for an FJ60, like 87-89 models. I could not believe how much lighter the gear reduction starter is compared to the OEM starter.
Got the water pump and t'stat housing mounted along with the mounting bracket for the GM pump. found out that I had purchased the wrong GM reman pump. so I had to order another one.
So here are the pics of what I done:
thats going to be nice when its done (also i've definitely visited your thread just never put 2 and 2 together)
