FZJ80 head torquing issue
Greetings all
Just got my head back from the machine shop and torqued the head down per the FSM, I unfortunately used a s***ty torque wrench that did not inspire confidence. went to my work to get a good torque wrench to double check. the bolts are well over 29 ft lbs, i tried to do the two passes of 90 degree turns but they will not budge at all. MY QUESTION IS will loosening the bolts per the FSM order and re-tightening them screw the new head gaskets integrity?
thanks guys!
definitely a different motor than the 2f and 3fe that I know, haha
The head gasket integrity would probably be fine. You might want to check out the bolts and make sure you didn't torque them past their yield point. The measurements are in the FSM. At this point have you done any of the 90 degree turns or did you just torque them to 29ft/lbs with the bad wrench and not go any further? It seems pretty strange you can't move them at all. Those last 90 degree turns should be done with a fairly long breaker bar to make it easier fyi.
On another note, if you did not use an OEM gasket then I would strongly recommend you consider getting one before you go any farther.
Head gasket integrity should be fine, I wouldn't think twice about it, and as mentioned by @scottryana check the head bolt length, especially if the head bolts are the originals and not factory new.
Nice, thanks guys. OEM gasket and original bolts. I didn't get too crazy with the breaker bar on my first HG job, so no 90 degree turns. Think I might back them out in the proper order and re-torque them tomorrow morning and not be such a pussy.
thanks for the help
The only thing I would add to help preserve the head gasket in this situation is to keep a few bolts with just a little torque on them.. just a little bit of clamping force would prevent the head moving at all while you alternately remove/check/reinstall the other bolts.
Glad you got it sorted out.
