Thanks Coolerman...your schematic sites are terrific! Thank you. What amp rating would you suggest?
Thanks again
My FJ starts, but then dies as soon as I let go of the key. I plan to layer this new AM circuit on top of old and test. I am just unsure of where BR wire connect to fuse block.
It an FJ40; not an FJ Cruiser.
If it dies when you let off the key, this is typically due to a bad / open ballast resistor.
You only need the one BY wire that is hot when the key is on. If it won't run with this wire hooked up maybe the key switch is bad.
You don't run a ballast resistor with a non-ballast coil. It may not run at all.
Cruisers that had a ballast resistor had another, smaller BY wire that runs from the starter solenoid that is only hot during engine cranking. If you had a ballast resistor and its corresponding coil, this wire would hook up directly to the coil + lug.
The only point of the ballast resistor set up is to improve cold weather starting.
Your diagram is spot on!
The PO may have installed that wire to bypass the bad WL wire. However that means the BR wire is now carrying ALL the current for the un-switched fuses AND the switched fuses. That is a fire just waiting to happen!
You plan to replace the whole AM circuit so you will get rid of that mess.
The comment I made stating the BR wire goes to key switch then on to fuse block meant that the BR wire goes to the AM terminal on the key switch, then comes out of the key switch on the IG terminal, and on to the switched side of the fuse block.
Here is the always on power wiring on a 69-71 FJ40View attachment 1376796
Do not run a ballast resistor if your coil has an internal resistor. That would drop the voltage at the coil to about 5 volts! I agree that the key switch may be bad unless of course you have the coil tied to the ST not the IG terminal.IG should remain hot with the key in the on position.
