fuel starvation?
CT
I'm a bit baffled and need some input on a fuel issue on my 79 FJ40.
Randomly, I get a fuel flow / starvation issue. I could go days without the problem or hours.
The truck will buck when trying to accelerate. sometimes it will clear up on it's own.
Sometimes, I can't drive more than a few mph in 1st and the bucking is constant.
I pull over, disconnect the fuel line from the fuel filter. No gas drips or flows out.
Blow on the fuel line and gas will flow, re-connect the fuel line and I'm good to go (for how long, I don't know).
I have not dropped the gas tank but that will be next.
I have drained the tank from the bottom plug. There was not any debris or rust particles that could be clogging the fuel line. I used compressed air to try and dislodge any particles.
I blew out all the fuel lines.
Before I disconnect all the lines and drop the tank (or replace it) any suggestions on what may be causing the issue with fuel flow?
Stock carb and fuel pump.
Thanks
sounds like you have something in your tank, I dealt with the same issues lately.
Have fun.
Next time it happens, remove your gas cap and listen to hear if it sucking air into the tank. If that's the case then the vent lines should be check because the fuel pump is creating a vacuum in the tank and simply can't over come it.
Carbon canister? Bypass and see if this temporarily alleviates it.
When you’ve pulled the fuel line off and get no fuel draining. Have you cracked the gas cap off to see if a tank vaccum exists? Might try that.
The randomness makes me think something is getting sucked in the fuel pickup. I think it was davegonz who found a leaf in his tank. Or could be a big chunk of something is in the fuel bowl and drops after the rig sits.
I thought, maybe, vacuum lock but did stop and loosen the gas cap to let pressure equalize. No improvement.
Actually seemed that pressure in the gas tank was positive not negative.
Guess I will need to drop the tank and see if a dead mouse or something is floating in there.
Thanks for all the suggestions.
49e89bb1-9477-494a-8fa1-ae053af38a9d-jpeg.1612030
I was experiencing the same symptoms you are having, pulled my tank and this is what I found! That is a leaf and a little ball of funk that looked like it had spent some time trying to work its way through the pick up line to the carb.
Vapor lock is my guess. Weak or defective fuel pump or a slight overheat issue. I would experience this most notably when my FJ was running hot with a near worn out radiator. Since the fuel line ran over the front of the exhaust and intake manifold, the near overheat operation would cause vapor lock at the after market fuel filter. I replaced my radiator and hasn’t Vapor locked since. May not be your issue, but a thought a bit out of the box.
Probably something intermittently blocking the fuel tank pickup, as others have suggested.
Couple of thoughts:
  1. When it fails, are you under load... like pedal to the floor, going uphill? Try the “paperclip test”, to ensure the carb secondary is working.
  2. A cam lobe drives the mechanical fuel pump. There’s a possibility that your cam lobe has worn unevenly and is not triggering the fuel pump. Here’s a 2009 discussion I pulled out of BBC cam issue-flat fuel pump lobe?
“kirban 2 cents worth
The lack of ppm of zddp in the oil will affect not just the cam and lifters but anything that has extreme pressure points in the engine. If you are running current oil has a star burst of SM on the container by law it only has between 600-800 ppm of zddp....before government intervention (EPA) it had 1,800 ppm.....
Also, cam wear will not be consistant. Issue is not just at break in anymore.
We are the largest seller in the US of zddplus sell direct to major companies such as Isky-Crower-Erson....among others...good friend of mine has produced it owns the largest collection of turbo buicks in the USA.....
if you send me a pm with your email I can have engineer email you info...”
If you bypass the tank and just run a hose from a gas can to feed the fuel pump, you can remove the tank and stock lines from the equation to narrow your focus.
That is exactly how I narrowed mine down to the fuel tank.
