Fuel pressure regulator weirdness
Tijeras, NM
Hiya fellas,
I got a weird one here that I can use your help with. I hope I've laid out a nice case for y'all!
Problem: my Torque app has been showing LTFT over 15% consistently for a while, and I've also been getting "fuel too lean" codes so I started to dig into this issue. With a turbo, running too lean puts us on edge.
So, I installed a fuel pressure gauge on the inlet of the fuel pump. This eliminates a dirty fuel filter (which is less than two years old) impacting the gauge reading. Sure enough, the fuel pressure at idle was 28psi. Disconnect the vac hose from the FPR and pressure went up to 35psi.
Internet says:
For your 1996 1FZ-FE, the FSM fuel-pressure specifications are:
Test conditionFSM specification
Engine running, FPR vacuum hose disconnected and plugged38–44 psi
Engine idling, FPR vacuum hose connected31–37 psi
5 minutes after shutting engine off≥21 psi
So, my fuel pressure is way off and I started some troubleshooting by going to my local buddy's place who has a '96 80 series NA with the original FPR. His numbers are exactly as shown above, so I figured if I stick his FPR into my engine, then I'll get the same psi reading. His pump resistor has not been bypassed so his pump was able to achieve those numbers with 9vdc (low speed mode).
Here's another kicker: when my FPR was installed on his engine, he wasn't able to get the FSM numbers which leads me to blame my FPR, which was installed with the turbo back in 2021. So, it's five years old. When his FPR was installed on my engine, it wasn't able to get the FSM psi numbers. Put his FPR back on his engine, and BAM, his has the FSM numbers.
Some things I've tried:
- bypassed resistor - no change in PSI.
-swapped out fuel pump relay with buddy's- no change in PSI. Still, I have a brand new one coming from Japan as a PM.
- ran a fused wire from battery straight to the pump POS wire - no change in PSI.
- used a bike pump to apply positive pressure to the vac port of FPR, and the pressure went up to 45psi. The more I pumped, the more PSI came out of the FPR.
- pinching the return line from the FPR to the tank bumped up the pressure to 45psi, so the pump (less than two yo) has no problem achieving a higher PSI.
- pump fuel sock is brand new when the pump was swapped out, less than two years ago.
-LTFT is now less than 10% with the pump resistor bypassed, which I shouldn't have to do but it's a temp bandaid for now.
-two weeks ago I got misfires from ALL cylinders. This tells me I don't have all six failing injectors, but something common to all six cylinders is the issue
- i have no intake air leaks/ or pirate air using a smoke tester.
-I also have no exhaust air leaks before the upstram O2 sensor (air/fuel ratio sensor)
-the fuel pressure doesn't nose dive under hard accels.
New issues, and perhaps related but these seems electrical, not mechanical:
The engine suddenly stalled on me while driving on a dirt road less than 20mph. The EFI fuse did blow so I'm investigating this on a parallel path. I might have an intermittent short around the fuse block under the hood. The CEL did not light up during engine cranking so that was my clue the EFI fuse blew. New EFI and COR relays coming from Japan.
Also, this happened twice so far: she cranks but doesn't start. Checked under the hood, nothing is amiss, tried again, and started up no issues. No blown fuses. Fuel pressure was 30psi each time so the pump was working fine.
If you're still with me, thanks for reading this long post. I'm sure I'm missing something obvious but my brain isn't able to figure it out.
Pump, fuel filters < 2yo
FPR = 5yo
FP relay+EFI+COR relays - all original, but will be replaced as a PM.
Have you checked voltages?
I recently had weird intermittent issues traced to loose EA2 connector. Toyota has it smashed between the fuse box and inner fender. Check all connections are good and solid. Check and clean grounds.
Also a long shot, but a crank, no-start with a club member was traced back to the ECU connector shown below beside the glove box inside the passenger side footwell. His had worked it's way loose over time and was causing the EFI Relay to be intermittent and showing low voltage which prevented proper operation of the relay in an intermittent fashion.
Its only a few screws and easy to check. Be sure all connectors are fully seated.
yup, checked voltages at the pump, and it's normal. With the resistor bypassed, it's a little under Alternator voltage output. There's a little voltage loss (measured to be 0.5vdc voltage drop across FRrelay contacts) between the battery and the pump, which is to be expected due to the original fuel pump relay. New relay en route from japan.
Now that's an interesting clue, let me look into it. If mine came loose, then that explains the stall on a dirt road, and maybe even randomly not wanting to start. Thanks for this.
re the new electrical issues - how is the condition of the fusible links at the battery?
the fusible link isn't old, but not fresh either. Probably less than five years old, but i'd have to check my log book.
I would verify proper voltage to the fuel pump.
Inspect connector BO1 under the body by the left C pillar. All FP connections run through that and it is exposed to the elements.
This voltage has been measured adnauseum at the FPrelay (before and after), at the pump, with idling, 1200rpm, etc.
What I don't get is this, and I've mentioned it before. Why does Leon's 80 can produce 40 psi at 9vdc using his FPR. Then I moved his FPR to my 80, and my pump is getting 12vdc+ and it still can't produce over 35psi.
These Denso pumps can easily produce high pressure even at 9vdc so I'm moving away from accusing my pump, which is two years old. I also swapped in the spare pump and it took only produced less than 35psi using my own FPR on my 80.
Speculating, but maybe the Fuel Pressure Regulator has collapsed internally and is causing a restriction...? (*but youve swapped it between vehicles 🤔) They're designed to be vacuum operated diaphragm valves that drop the flow under vacuum to lower fuel pressure by opening the valve more under vacuum, per your FSM statements.
@petegangies said elsewhere; "...one thing to check (only because this exact thing happened to me), is pop the vacuum hose off your fuel pressure regulator, make sure there's no fuel in the vacuum hose, it should be bone dry, if there's fuel in it then the diaphragm has failed and will need replacing."
I know where your head is at and mine was there also. Swapping a known good FPR into my 80, then under performing, then swapping it back to the other 80, and then performing per FSM has me complete bamboosled.
But, why didn't my FPR behave normally in the other 80? That also has me stumped.
I also pumped up the FPR inlet port with a bike pump and the pressure went up to 45psi, in my 80. So the positive pressure aspect of the FPR seems to be working.
The vac hose to the inlet is in fact bone dry, and that jives with the fact that the FPR is five years old, installed at the same time as the turbo.
Just for S&G, I bought a cheap amazon FPR as an experiment to see if anything would change with the pressure. Unfortunately, no change, but it did exonerate the OEM FPR. I also checked the vac at idle and it's rock solid at 15 hg.
Fuel pressure takes more than five min to decrease to a lower number than 28psi but the injectors aren't completely exonerated yet. LTFT is still too high but it's a lot lower than before.
I'll keep plugging away. I'm heading to UT tomorrow, so when I return, I'll move the pressure gauge port from the inlet of the fuel filter to the outlet of the fuel filter to see if that makes any difference.
Pinching the return hose does bump up the pressure to 45psi so the pump is good.
I now have a brand new fuel pump relay, not that it was an issue but there I measured 0.5vdc drop across the old contacts. I'll be swapping out the EFI relay and the COR relay next.
I also monkeyed with the fusible links while the engine was idling, hoping to stall the engine, but no change.
I do think I may have found the "no start" issue even with normal (for this engine) fuel psi.
Someone has mentioned I need to check the return path to make sure it's clear of any obstructions so i'll also hit that next weekend.
I've been monitoring the temps of the EFI relay while looking at the current draw of the EFI fuse wire. I brought the meters into the cab for monitoring while driving. I may know why the EFI fuse kept blowing, but don't know the cause of it yet. My current clamp pegs out over 30amps for a brief moment while I'm driving, but it doesn't happen consistently. The temp of the EFI fuse is warmer than ambient, but the clamp shows a consistent draw between 7 and 9 amp. The pump draws 7 amps by itself, so that makes sense. When you add the draw from the injectors, IACV, MAF and whatever else, the total comes out to 9 amp on occasion.
The EFI relay likes to hover around 170 deg on warmer days it seems. 145 deg F is on the spare EFI relay sitting next to the current one.
My LTF is still around 12-14% so i'm still running lean which means my fuel psi is low.
After an engine and fuel system rebuild (hard parts i.e., pump, filter, regulator, injectors, flexible lines) my FP is 50psi no matter rpm. Runs good but…. According to Toyota something is not right kinda like your weak 15 hg vacuum at idle. It should be 21-22.
Engine vacuum decreases as altitude increases, roughly by about 1 inch of mercury (Hg) for every 1,000 ft of elevation gain, due to lower atmospheric pressure and air density. So with an average elevation of 6600 feet in Tijeras New Mexico where he lives his Vacuum could in fact be correct at 15 inches at idle.
Check…
Thanks for pointing that out, and you're spot on. My house is at 7k' so 15 Hg seems appropriate for this elevation.
Now this is interesting info you just provided. Your pump is producing 50psi with or w/o the vac line connected? FSM says the psi will go up just under 45psi and you're at 50 psi :oops: Are you running the factory pump and FPR as well?
Brand new Aisin pump and new OEM regulator. Yes, 50psi all the time. I bought one of those adapters @cruisermatt sells and permanently mounted a Holley liquid filled FP gauge. Another member I communicate with semi regularly installed the same gauge after I did and registers FSM pressures so I’m assuming my gauge is fine. I’m not so much concerned about 50psi under load but don’t want to over work the pump unnecessarily when full pressure is not necessary.
Also, I installed the C&C stage 1 turbo kit as I built the engine compartment up and my A/F ratio gauge will note stay steady unless I mash my foot down and the ecu goes full rich. It runs great but it is possible my ecu is trying to correct a rich mixture due to high fuel pressure. Not to jack your thread.
