Fuel mileage drop help
denver
So I have been noticing my millage going down hill for a few months now but this last tank it seemed I could see the needle going down 185 miles full to empty. It has 305k on it I gave it a full tune at 300 plugs wires cap timing CEL is off this last tank had me looking for a fuel leak it was so bad 😫. I was thinking maybe I have a bad pressure regulator or leaking injectors thoughts anyone
Some relevant information about your truck would help get you some answers.
What engine, What year, What country of origin
What is meant by "a full tune"?
What Jon said as well.
I would bet it is your temperature sensors. The 1FZ-FE engine uses the temp sensors to indicate to the ECU that t is up to temp and it will go into closed loop operation, VS open loop (like when the engine is cold) and it uses more fuel.
Sorry it's a 1996 1fz-fe stock has a snorkel but been there a few years it's in Colorado but not the mountains. Full tune means plugs wires air filter fuel filter cap rotar fuel injection BG and timing set per FSM.
Larger tires, inflated to the same PSI as before the loss of MPG??
Same power/acceleration as before? Any stored codes?
yep, 02 sensors was my issue.
I guess I need to get plugged in and see what it's doing haven't had a chance to look into it rear heater water pipe broke on it just repaired it today. Also rear brake job is about year old replaced everything back there no dragging
I used to get about 11.8mpg during the summer and as soon as winter blend hit I'd get 9.2 at best. Go fill up on some clear gas and see if your mileage rebounds. If it does, I'd hold off on any parts purchases until summer. If it remains decent through the summer you'll know it's just winter blend fuel.
This has always been my case.
It is a pretty prevalent problem here in Oregon. Being a former shop owner of an honest shop I advised clear gas in the winter countless times over needless repairs. 9/10 times it was the fuel that was the issue.
well still haven't track down whats going on, rear heater pipes rusted through and has been side lined for a bit still leaking a bit so i haven't been driving it. i can try ethanol free gas to see what happens they sell by my house pretty sure i have a leaky injector or two
Fuel to empty, how many gallons to fill would be helpful plus the question on tire size
