Fuel Injectors
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Well I have what I think in my 93 FZJ80 a bad or few bad injectors. Problem started about 5 months ago with a slight hesitation upon acceleration. It progressively got worse through idle all the way up to around 3000 rpms. I can go outside in the morning and start it up and it will start fine and idles okay. I can feel a miss but I cannot hear it. It's only until I put it in drive that it really has issues. From right off idle in drive it will miss badly to the point I can hear it backfire. Once I get it over 2000 rpms it quits and starts to run a bit smoother but it still runs like it's only running on 5 cylinders. After it has gotten a chance to warm up the RPM at idle in gear are around 450-500 and I can really feel it miss.
In the beginning I thought it was electrical. SO I replaced all the spark plugs twice. The cap, rotor button. I've checked the timing. I removed the dizzy and replaced the seals as I thought the leak the dizzy had might be getting inside the cap and causing issues. Checked the reluctor circuit and all is up to spec. Replaced any Vac lines I thought were suspect. Sealed the intake hose and check for any leaks. Checked and tested the EGR system. I think it the main pipe from the exhaust could be clogged a little but there is no way I can budge that compression nut. Cleaned the EGR modulator and it was clogged but once cleaned it tested out fine. I've also checked the throttle positioner. Works just fine. And lastly I have checked every single wire on the engine harness. All Ohm out to spec. I even removed the harness from the top of the motor, inspected it, cleaned it and then re-wrapped it with a layer if Silicone tape and then a layer of heat shield.
Still my problem persists. So now on to the injectors. Reason I did them last was I just had them cleaned by Toyota 30k ago. I thought they wouldn't be an issue. This cruiser does have 232k on it though.
So I traded a few parts out for a set of injectors off a 96 FZJ80. Plan on just sending those out to be cleaned. My question is were the 96 and 93 injectors the same? Just want to make sure before I spent the money on something that won't work.
I also got a throttle body of the same 96. Has anyone tried to use the throttle positioner off a later cruiser on an early cruiser. Wonder if one works better than the other?
The injectors are the same part number.
I believe that the TPS is the same(but not %100 sure), look at the numbers on the side of the TPS. These are all printed circuit board type, no copper strips to wear. But over time they do fail as well.
Had plug wires cause similar problems, even though they seemed to test as OK.
Plug wires were changed during all this mess. They are OEM. Didn't fix the problem. I don't think it is electrical but it sure does feel like it.
My vote is on the injectors.
What about the wire harness around the EGR pipe?
